  4. App restarting when Bluetooth keyboard connected (WunderLINQ)
11 Posts 4 Posters 2.5k Views 3 Watching
  • stuart marritt
    stuart marritt
    stuart marritt
    Hi
    I have just discovered an issue in that MyRoute-app will restart every time a bluetooth or physical keyboard connects to my phone.
    I use a WunderLINQ controller which is basically a Bluetooth keyboard and when I switch the bike on or off or even start it MyRoute-app will restart itself meaning I have to restart the route again. This also happens if you attach a physical keyboard to the phone.
    Here is a link to a video I took showing the issue.
    https://youtu.be/0Vbvf68hBwg?si=Z1GhH5o8FHAJTFB4
    • Andre Trudeau
      Andre Trudeau
      Andre Trudeau
      wrote on last edited by Andre Trudeau
      @stuart-marritt Let me guess, you have an Android device? I have the same issue..
      I also bet that if you connect your 2nd keyboard with the USB dongle and then repeat the test, connecting/disconnecting Wunderlink keeping the USB dongle/Keyboard connected, you will not see the issue...
      From my testing it does not occur on Apple devices...
      • stuart marritt
        stuart marritt
        stuart marritt
        Yes I have a android device
        I will try the second keyboard trick and see what happens although it's not ideal
        • Andre Trudeau
          Andre Trudeau
          Andre Trudeau
          @stuart-marritt Indeed not ideal.. It is more to confirm my suspicions regarding this bug. The second Bluetooth keyboard "trick" seems to prevent the cycling of the app because there is at least 1 keyboard available. The issue occurs when MRA goes from no keyboard to 1 and vice-versa. I have a ticket open on this but no mouvement so far.
          stuart marritt 1 Reply Last reply
          • Andre Trudeau Andre Trudeau
            stuart marritt
            stuart marritt
            stuart marritt
            @Andre-Trudeau as you said with another keyboard attached via the USB the Bluetooth keyboard when connecting and disconnecting has no affect and works as it should
              I am fairly confident this issue will be resolved in the 5.0.1 release this week!
              Please let me know 😃
              • stuart marritt
                stuart marritt
                stuart marritt
                Once the release drops I will test it and report back
                • Robert Laudensack
                  Robert Laudensack
                  Robert Laudensack
                  I had to stop using my small keyboard I wanted to use to start stop music as MyroutApp was crashing when I pressed the buttons
                    That will definitely be an issue of the past when 5.0.1 becomes available to you!
                    • Andre Trudeau
                      Andre Trudeau
                      Andre Trudeau
                      The restart when bluetooth keyboard has been fixed in the new release. I just confirmed it on 2 android devices. Thank you!!!
                        Great to read that! Thanks for confirming 🎉
                        stuart marritt
                        stuart marritt
                        Andre Trudeau
                        Andre Trudeau
                        Robert Laudensack
                        Robert Laudensack
                        • Statement on map spinning
                          hawebo
                          hawebo
                          1.7k
                          Bart 9a 0
                          Bart 9a 0
                        • Electric Car Travel Mode
