  4. MRA 5.0.1-430 Menu in full width after turning phone
8 Posts 5 Posters 90 Views 3 Watching
    during playing with the new version on my Android tablet, I turned the phone from landscape to portrait and back. After this the menu takes the full screen and no map was seen anymore.
    From here:
    to here:
    This status stayes until navigation starts.
    You also can not reach the settings.
      From here:
      to here:
      @Jörgen I can confirm this but its also the case on an Android phone. Once you've changed from portrait to landscape the menu is full screen.
      Starting in landscape the menu is as it should be but once you changed it to portrait and back to landscape the menu is full screen
        In V426 it is correct working.
          @Jörgen : For me it works perfectly in the version MRA 5.0.1-430 on the iPhone 16e !
          Jörgen 1 Reply Last reply
            @Hubert-Thoring said in MRA 5.0.1-430 Menu in full width after turning phone:
            I know Hubert, I can check iOS as well.
            • richtea999
              Comparing the two platforms in landscape (and running MRA 5.0.1-430 on both):
              • iOS menu takes the left side of the screen only, so you can at least reach the Account button
              • Android takes the whole screen, blocking any usage
              The main issue, though, is that neither platform allows you to pull the menu down / away to a minimal height. They both hog the screen, stopping normal use.
              iOS screenshot for comparison with Android ones above:
                I’ll get this fixed before release! Thanks for sharing
                Edit: to be clear, the issue originally mentioned. Not being able to drag the menu down in landscape, is not the issue 😉
                  Can confirm it has been fixed
                  • Opstarten app in Android.
                    Beemerfrankie
                    Beemerfrankie
