  4. Next beta 5.0.0(426) And SilverFox problems
13 Posts 3 Posters 119 Views 3 Watching
  • Lluis Arasanzundefined Offline
    I'm using a remote device as controller for Next, but I see some misfunctions or errors.
    To replicate at home I use a Bluetooth keyboard to simulate inputs.
    In navigation screen if I open the menu and select ‘up’ arrow, instead of select 'stop navigation', highligh disapears, until i press 'down' arrow or again up arrow to reach configuration icon. After I reach configuration icon, up and down highlights every menu option.
    If I use left arrow on any menu item, all items upwards are not highlighted until I reach configuration Icon.
    Also, I noted that when I Try to stop navigation, selecting item on menu, I do it and also accept question about “sure?” … but popup about “restart navigation?” Cannot be cancelled or accepted in any way, only by screen touch.
    I try also “standard input” and behavior is the same.
    Not sure if this replicates on public release
    I’m trying to do a video to show it
    F750GS
      Here is a video
      https://drive.google.com/file/d/18mtcEyTg66X_-Ti3nFYLhtH6gm6pO5oF/view?usp=drivesdk
      F750GS
      • CD130undefined Offline
        Same experience here on an iPhone and a bluetooth keyboard. It has nothing to do with SilverFox.
        Lluis Arasanzundefined 1 Reply Last reply
        • CD130undefined CD130
          @CD130 I have a question for you:
          If you open MyRoute first and then you turn on Keyboard, MyRoute crashes when Keyboard connects to phone with a black screen and there is nothing to but force close app?
          I detect this behavior, but I don not know if it's a problem of MyRoute or my phone.
          F750GS
            Sure, I enabled the keyboard in several places within the MRA app (it connected automatically). I noticed that the on-screen keyboard kept disappearing and the app itself didn’t crash.
            I’m using an iPhone 16 Pro and a Logitech Bluetooth keyboard. Which phone and Android version are you using? That might be useful information for the app developers.
              I'm using Samsung A14 device and Android 14.
              When I use bike controller, all is fine in connection, but if I use a Bluetooth Keyboard, not.
              Is MyRoute is started, on main screen or on navigation screen, MyRoute becomes a black screen. If I turn on MyRoute after connect my keyboard, all works fine.
              But, perhaps is my device. I comment out only after knowing you also use a BT Keyboard.
              F750GS
              • Lluis Arasanzundefined Lluis Arasanz
                @Lluis-Arasanz Just tested with Remotec One (Bluetooth remote on my motorcycle) and found the same problem. Created a ticket and referred to this topic.
                  @CD130 Perfect.
                  I'll check on motorcycle when connecting remote controller to phone, testing if I have MyRoute-app opened before or no.
                  Thanks
                  F750GS
                    @Corjan-Meijerink Hi, are you able to reproduce this issue? Otherwise I can record a few videos and share them with Rob. When you go to the main menu, choose 🔍 and use the left and right arrows on the Bluetooth keyboard, things go wrong as well. Just tested in 5.0.1 430. Hopefully you can fix it in the future.
                      This problem does not reproduce on Android if my "bluetooth device" is not a Keyboard. Perhaps has some interaction with Keyboards Issue that are corrected on 5.0.1. I'll check it when update available to Android.
                      F750GS
                        I believe these issues will be solved in the 5.0.1 update 😃
                        Let me know once it's available!
                          @Corjan-Meijerink oh, that is good news. It is still present in 5.0.1 - 430, is that correct?
                            Yes. Made some changes today.
                            Will be in the 432 build.
                            CD130undefined
                            • Update 5.0.2 - Free drive
                            • geen visuele waarschuwing flitscamera (snelheidsradar)!
                            • cant use app just to view map when riding
                            • Waaldijk Afsluitingen
                            • Mobile data usage
                            • New beta! 5.0.2 (438) - free drive
                              b0hd1undefined
                              421
                              Erik Plaggenborgundefined
                              Erik Plaggenborg
                              3.0k
                            • How do I follow a track not Navigate it
