  4. Auto-zoom could still use some love.
11 Posts 5 Posters 4.2k Views 5 Watching
  • Paul Steinberg
    Paul Steinberg
    Paul Steinberg
    Great work on v5 everyone. As a lifetime member it's encouraging to see the app evolving.
    One feature that both Google Maps and Garmin handle quite well is auto-zoom. The map scales back to show the road ahead until your next turn and gradually zooms in as you approach the turn. If the next turn is a long distance, they tend to show the next 10-15 min up the road.
    MRA on the other hand tends to stay zoomed in too close for you to have an idea of what is coming up ahead. I have tested out changing the default zoom to, say, -1.4...but that adjustment is applied to even the turns which makes it harder to make sure you're turning on the right road.
    Here are some examples comparing Google Maps in 'direction up' view against MRA in 'dynamic camera' (all other settings default). The snow is on the ground here in Toronto so I'm using the Android Auto link to my Ford F150 screen instead of my 1250GS+Chigee. I've set a Gopro to record the same drive to the grocery store.
    Could the autozoom feature get a little more polish to closer match the display of Google Maps or Garmin while navigating?
    2022 R1250GS
    Google Pixel 10XL
    Android Auto
    Chigee AIO6
    Brian McG 1 Reply Last reply
    • Paul Steinberg Paul Steinberg
      Hi @Paul-Steinberg could you please advise if your issue is solely with Android Auto?
      What you describe above is exactly how MRA works in dynamic mode as I explained here in another thread when the app is run directly on a phone & not via android auto
      As your screen shots are android auto I cant tell what compass mode the app is in, it looks like it is "heads up" which as explained in the other thread does not have any auto zoom
      • Paul Steinberg
        Paul Steinberg
        Paul Steinberg
        wrote on last edited by Paul Steinberg
        hey @Brian-McG ,
        Yes the MRA compass mode is in dynamic mode (I did try all modes and dynamic was the best results but still not very good). When I get close to a turn it does zoom in similar to Google Maps (see screen shot of a corner), the issue is that after the turn it doesn't zoom out far enough when you're driving down a road. I can manually decrease the zoom (in the in the options) but that zoom is then applied to the turns as well. This is leaving you to decide to see down the road or see the turns when it should be doing both.
        I didn't test it on the phone-only as I'm always using MRA with Android Auto, whether with the Chigee AIO6 on my bike or with native screen in the truck. I'll try it on the phone tomorrow an report back.
        Google Maps has an effective auto-zoom in AA. It tilts back and zooms out to let you see the road ahead until the next turn. As you get to a turn it is continually zooming in until it's it top down and the turn fills the screen, then it zooms back out. Would make for an easier to read while riding, more relaxed navigation experience if MRA could get similar auto-zoom in AA or Carplay.MRA04.jpg
        2022 R1250GS
        Google Pixel 10XL
        Android Auto
        Chigee AIO6
        • RetiredWingMan
          I agree that the auto zoom can be improved to be smoother and provide more assistance to the rider.
          • Paul Steinberg
            Paul Steinberg
            Paul Steinberg
            I did try a test with just the phone as a display and found the auto zoom as bad, if not worse, than on Android Auto.
            2022 R1250GS
            Google Pixel 10XL
            Android Auto
            Chigee AIO6
              Define "just as bad". In Android Auto the Autozoom is not good. Totally agree.
              On the smartphone self it is better. You have more settings to use. I tried HereWeGo also. If you do this. You'll see similarities
              How HereWeGo use the autozoom is not my preference. But that is not the same as a bad autozoom.
                Hi @Paul-Steinberg as I mention in the other thread it is possible using MRA directly on the phone in dynamic mode to have the auto zoom pan out to over 15 miles & zoom into just a few hundred meters as you approach a junction
                The first picture below shows the dynamic zoom set at -1.0 which shows over 15 miles of route ahead when the next turning is >3 miles & the speed is high
                As the junction approaches you can clearly see in dynamic mode the map is zooming in as the mileage to point 2 decreases
                This second picture shows the same route with dynamic zoom set at -0.2 which shows over 5 miles of route ahead when the next turning is >3 miles & the speed is high
                In an ideal world some might prefer a different gradient of zoom levels so you get the far range of -1.0 & the closeup zoom of -0.2
                (but why anyone needs to see as far ahead as -1.0 allows is beyond me 😂 )
                Frankly I think the zoom function works pretty well, as least as good as Google where you don't get any option on how much it zooms
                I would certainly not say it is "bad", is it perfect, no, could it be better, maybe yes, but how it could be better I am not so sure I could define,
                what I prefer as a zoom gradient is going to differ to what others would like, its always going to be a personal preference, as we all ride at different speeds & some prefer to see further others not so much, so I think the zoom slider with its different ranges is quite a good comprise
                If on your phone you are unable to get the zoom function correctly as above, I doubt you have any chance of seeing it work right with android auto
                • Paul Steinberg
                  Paul Steinberg
                  Paul Steinberg
                  Sorry, 'bad' wasn't a good description. I'm just not understanding the road at a distance or the details of turns in MRA dynamic view anywhere near as well as the Google Maps default 'perspective' view.
                  I did try just using the phone-only with mixed results. I found the autozoom pretty similar to what I'm seeing on AA but at some point the position indicator moved to about 1/3 from the top of the screen (so 2/3 of the screen is where I've been) and it didn't go back on it's own. I was driving so I didn't have the chance to fiddle with it to try and reset it.
                  I think the default Google Map behavior is excellent...hey, I'm sure they have a huge team working on it. I agree that you don't have the user options in GM like you do in MRA but honestly, GM just works great.
                  Look at what GM is doing...when you're on a long stretch the map view zooms out and tilts up to give you an excellent understanding of the road ahead. It looks like it zooms out to show you up to the next turn unless it's a very long distance, then it stops at around 5km(ish)or so. As you get closer to a turn, GM gradually zooms in and tilts down until it is directly over the position indicator and showing excellent detail of the turn. At a glance I clearly understand where I am and what to expect as I ride down the road or enter the turn. This works on phone or any AA screen I connect to. Again, I'm sure they have a small army working on it so it's not a surprise it works really well.
                  I'm a lifetime member or MRA so I believe in the product, I'm just having to guess a bit either on the road or going into turns when I'm using it. Thankfully Google is doing the hard work of research and development. The wheel doesn't need to be re-invented here.
                  2022 R1250GS
                  Google Pixel 10XL
                  Android Auto
                  Chigee AIO6
                    @Paul-Steinberg you can alter the "perspective" with the "Tilt Correction" adjustment in "Navigation Settings > Map Layer > Map Layer"
                      The tilt correction does not have any effect in AA.
                        @M.-Schrijver said in Auto-zoom could still use some love.:
                        Same for me !
                        Adrian
                        Paul Steinberg
                        Paul Steinberg
                        • Strange translation
                        • Crazy routing
                        • Foutmelding In MRA Next
                        • Kort voorstellen
                        • My Routeapp Stays questions
