  4. Faint green border appears when app is navigated with bluetooth device
18 Posts 4 Posters 3.4k Views 3 Watching
  • Andre Trudeauundefined Offline
    Andre Trudeau
    wrote on last edited by Andre Trudeau
    Hi all,
    Using a tablet (DMD-865X), a faint green border appears around the MRA app as soon as an input is done using a bluetooth device (keyboard/remote).
    Anyone else experiencing this?
    More visible in dark mode:
    Still there in Light Mode but faint:
    Cheers!
    • Andre Trudeauundefined Andre Trudeau
      Hi all,
      Cheers!
      @Andre-Trudeau no but a picture paints a thousand words
        Andre Trudeau
        @Marinus-van-Deudekom Amended my post. Curious to see if you have same issue with your DMD tablet.
        Thanks!
          A BT keyboard, under iOS also shows a frame when you start the pairing.
          With iOS you can choose the color and also the time how long a frame should appear, whether it exists on Android I can not say.
            Andre Trudeau
            @Hubert-Thoring Well.. I have no such settings and the older app never did this.
            This occurs on both my DMD tablet and my Samsung phone...
              Thanks!
              @Andre-Trudeau Hi Andre
              Just checked out on mine
              I do have that faint green line around the app.
              To be honest I never looked at it before so I don't have a clue of that's something new or not.
              My remote works ok
              Unlike you I don't use mine in full screen mode. Thus having the possibility to have direct access to other apps using the device bottom toolbar
              The screen itself is that big that I find it handy like that.
              Have fun.
                Seems like an Android only thing when a keyboard is connected.
                I believe I found a fix which I will communicate here once implemented.
                Not something urgent 🙂
                  Andre Trudeau
                  @Marinus-van-Deudekom What remote do you use? Would you willing to test something since you have the same tablet as me? Make sure you have no Bluetooth remote/keyboard connected on the DMD-865X. Start MRA. Start a route. While MRA is being displayed, connect remote or bluetooth keyboard. Does the screen go black or are you asked if you want to continue navigation? Mine goes black..
                    @Andre-Trudeau I use the SilverFox H1
                    I will give it a try and report back here
                      Andre Trudeau
                      @Marinus-van-Deudekom Perfect. Thanks!
                        Should indeed be resolved in the next update
                          Just checked it
                          Started a route without any Bluetooth device being connected.
                          Then connected my SilverFox via Bluetooth.
                          The screen refreshed and kept on navigating without any question being asked.
                          So for me it works perfect
                          Have fun
                            Andre Trudeau
                            @Marinus-van-Deudekom Thank you very much. Cheers!
                              Andre Trudeau
                              @Marinus-van-Deudekom I have a question. When you say the screen refresh, are you seeing the MRA app restart and resume navigation automatically? Or just a map refresh? Try as I might, I cannot get MRA to not "cycle" and ask me if I want to resume navigation on my Samsung S24. I have given up on my DMD tablet because I am dealing with a possible hardware issue with it. The only time I do not get asked on my Samsung is when I have 2 keyboard devices connected. Then I can disconnect/connect 1 without issue.... And as a side note, my IPad Air 5 behaves absolutely perfect in that regard. No MRA App cycling...
                                @Andre-Trudeau of you have a hardware problem with the Thork tablet, just contact them. They have a good service regarding issues with the tablet.
                                Is that tablet up to date. When I connected mine last week it had to restart 3 times to get all the updates installed. After that it runs as before, perfect. If you regard the price of the 865X one might expect great Customer Service.
                                  Andre Trudeau
                                  @Marinus-van-Deudekom I did and Thork is taking care of it 🙂 Fabulous support on their part. I was just asking because I have the issue of MRA restarting on bluetooth keyboard connect/disconnect on multiple devices. No worries. I'll wait to get my replacement 865X and re-test. Cheers!
                                    Andre Trudeau
                                    Great job! Both the green line and the bluetooth disconnect/reconnect issues have been fixed 🙂 Thanks!!
                                      Most welcome! 😃
                                      Andre Trudeau
                                        Massimo Cardoneundefined
                                        Massimo Cardone
                                        2.6k
                                        Axel Härtlundefined
                                        Axel Härtl
                                        Aiello antoninoundefined
                                        2.9k
                                        Jan Weerheimundefined
                                        Jan Weerheim
                                      • CarPlay says that I need a subscription
                                      • Doe ik iets verkeerd of...
                                        Michel 71 0undefined
                                        Michel 71 0
