  4. Unable to start a route using remote.
13 Posts 3 Posters 2.6k Views 3 Watching
  • Andre Trudeau
    Andre Trudeau
    Andre Trudeau
    wrote on last edited by Andre Trudeau
    Althought I like this new 5.0 version, it changed how you can select and start a route.
    Using my remote, I am able to navigate and choose a route like before.
    But I cannot select the "Start" button. I can navigate everywhere else, including the edit button. I need to use a touch to start it.
    Anyone having the same issue?
    Am I missing something?
    Cheers!
      @Andre-Trudeau :
      Which remote control do you use?
        Hmm, that is strange.
        As soon as you enter that screen and press “up”, what happens?
        • Andre Trudeau
          Andre Trudeau
          Andre Trudeau
          @Corjan-Meijerink, Interesting.. As soon as I enter that screen if I press up it brings me to start. I can go back and forth between start and edit, but as soon as I go further up(waypoints, route settings etc) and come back down to the Start/Edit, the only selectable one is Edit. Got to say pressing up first thing is not very user friendly 😉
            No definitely not!
            The honest answer is that I have no clue yet why that works but just wanted to share that it works 😛
            I'll investigate the issue and work on a fix but at least you now know a workaround.
            • Andre Trudeau
              Andre Trudeau
              Andre Trudeau
              @Corjan-Meijerink ,
              Thank you!
              Still have the App crash on bluetooth keyboard/remote disconnect/connect events btw. I did report this on my existing ticket.
              Cheers!
                I've seen that the ticket too.
                That's even weirder 😉
                • Andre Trudeau
                  Andre Trudeau
                  Andre Trudeau
                  @Corjan-Meijerink ,
                  Good 😉 At least I am not crazy.. lol!
                  • Andre Trudeau
                    Andre Trudeau
                    Andre Trudeau
                    @Corjan-Meijerink ,
                    Discovered something new for the Bluetooth issue...
                    The issue does not occur if I have 2 "input" device connected and 1 is disconnected.
                    Could you try this to confirm you are seeing the same?
                    Cheers!
                      Just edited my response. I've seen your ticket but not the actual issue itself 😉
                      Not able to reproduce it at all.
                        Both the app crash on connecting controller and this issue should be resolved in the 5.0.1 update. Please let me know when available 😃
                        • Andre Trudeau
                          Andre Trudeau
                          Andre Trudeau
                          Will test and report. Thank you!
                          • Andre Trudeau
                            Andre Trudeau
                            Andre Trudeau
                            Both these issues fix on 5.0.1. Thanks again!
                            Andre Trudeau
                            Andre Trudeau
                            • Statement on map spinning
                              hawebo
                              hawebo
                              1.7k
                              Bart 9a 0
                              Bart 9a 0
                            • Electric Car Travel Mode
