  4. MRA 5.0 with very Curvy different between Handy A to B and iPad A to B
7 Posts 5 Posters 66 Views 3 Watching
    Unbelievable on a route A to B from Münster - Winterberg
    However, the avoidances for very curvy, which are preset by MRA, are different between iPhone and iPad with the same A to B input and this results in different routes without the user knowing it...
    The avoidances are even preset by MRA when very curvy !!
    Note: the navigation settings / functions are set the same on both devices!
    How can that be?
    Picture mobile phone iPhone
    Picture iPad
      M. Schrijverundefined Offline
      Is it the same version on both devices?
      Why?
      On your IPad picture i see the option "Zugelassene Strassen"
      On your IPhone picture this option isn't visible.
        Yes same MRA 5.0 version, only on the phone the menu is moved a little up to see all settings.
        Impact between iPhone with iOS 18.7.1 and iPad to iPadOS 26.0.1 ..?
        Yes, see also there the resulting question for me:
        https://forum.myrouteapp.com/post/70329
          @Hubert-Thoring your settings are not the same. That will create differences
            Yes, why are the standards specified by MRA different...
            I only selected very curvy and that with both devices without anything to adjust, and the settings were not the same. I haven't changed anything about it...
              I would consider it a feature when curvy routes differ each time.
                We definitely do not guarantee identical scenic routes across devices with same settings. Better yet, if you generate the same scenic route on the same device you will probably get different results too. There definitely (by design) is some variation.
                • Veekeersinfo en omleiden
                  Herman Veldhuizenundefined
                  Richard 18undefined
                  Richard 18
                • Skipping a Via point...
                  Bouke Entundefined
                • Skip square symbol in the Waypoint attribute pop-up window?
                • Request login credentials
                  Aiello antoninoundefined
                • Web App isn’t stable
                • Library sync error
                  Albert van den Elsenundefined
                • New roads visible in Google map but not Garmin Here
                  Bouke Entundefined
