  4. construction of a path without logic and different from Maps
10 Posts 4 Posters 2.9k Views 1 Watching
  • Giuseppe Marino Offline
    Giuseppe Marino
    Buongiorno, capita spesso che quando si pianifica un percorso si creino deviazioni illogiche che non esistono con Google Maps, come potete vedere nei file allegati. Questo problema esiste in tutta Europa. Io uso le mappe Here per il Garmin Zumo XT2. Lo stesso problema si verifica quando si pianifica dall'app Android. C'รจ una soluzione a questo problema, perchรฉ รจ molto fastidioso percorrere diversi chilometri e poi dover tornare indietro per lo stesso percorso? Grazie mille. ![alt text]Screenshot 2025-10-09 155132.jpg Screenshot 2025-10-13 122423.jpg Screenshot 2025-10-13 122757.jpg
    • RetiredWingMan Offline
      MRA just wants to make sure you see all the good roads! ๐Ÿ™‚
      Share the link to the route and someone may be able to explain.
      Giuseppe Marino 1 Reply Last reply
      • Con Hennekens Online
        @Giuseppe-Marino, It looks like at the crossing just before WP5 it is not allowed to turn left. I checked that with mapcreator though, and it looks like it is already corrected.
        https://mapcreator.here.com/navlink:832838576/?l=46.4154,12.7650,18,normal
        I have no idea if there is a version difference or update schedule to which the MRA maps sync with HERE.
          Giuseppe Marino
          @RetiredWingMan ๐Ÿ˜ƒ
            Giuseppe Marino
            @Con-Hennekens Yes, I also like MRA and use it with my laptop during my motorcycle trips, but I've noticed that using the HERE map for planning often results in a lot of errors. While I'm riding, I notice the errors and almost always don't follow the navigator's absurd turns. Currently using Open Street Maps, however, it doesn't report the same errors as HERE. However, I need to try exporting a route created with OSM to GPX 1.1 on the ZUMO XT2 and see how it behaves, obviously disabling automatic recalculation. Thanks for your support. Screenshot 2025-10-13 175958.jpg
              Giuseppe Marino
              I've done some tests. The best solution is to plan using Open Street Map (which doesn't show road errors like HERE) and export to gpx 1.2 instead of 1.1. Then, in my case, import only the route from the navigator and not the track so that the navigation also includes the list of points on the route that I've indicated as waypoints.
              Alex reds Con Hennekens 2 Replies Last reply
              • Giuseppe Marino Giuseppe Marino
                Alex reds Offline
                Alex reds Offline
                Alex reds
                wrote on last edited by Alex reds
                @Giuseppe-Marino
                Hi Giuseppe, this is what I usually do. First, I plan using the here map, then I use the toolkit to compare it with TomTom and check the differences. This usually fixes those strange route deviations.
                • Alex reds Alex reds
                  @Giuseppe-Marino
                  Giuseppe Marino
                  @Alex-reds Many thanks. I only have the Gold subscription on the Android app and not on the web portal, and I can't compare it with the TomTom maps ๐Ÿคท
                    @Giuseppe-Marino, I do not have such a bad experience with HERE at all, although I must admit that during our French Alps week, I noticed some strange situations where HERE thinks there is a road straight uphill, bypassing hairpin corners, which were not there in reality. So yes, every map has errors, seldomly the will have that all on the same spot I guess ๐Ÿ˜‰
                    The 1.2 version GPX is a non-official method that only shows you the VIA points. The route between those are formed as tracks. When you use the OSM maps for planning, and while navigating by HERE (you do not have a choice there, MRA Navigation is HERE only) you may be introducing other problems.
                    Gold subscriptions only exist on the web-planner. So if you claim to have Gold, you actually DO have the comparison tool available. If you do not have that available, you do NOT have the gold licence (not for the account you logged in with anyways).
                      Giuseppe Marino
                      @Con-Hennekens Thanks for the reply. I'll do a road test in the next few days with a route created with OSM and then sent to the Zumo with GPX 1.2 on which I inserted the waypoint. I'll also try leaving the "route recalculation" option set to ASK to see how the Zumo XT2 behaves. As for the license on the portal, I have the BASIC one, while on the app I have the lifetime one, and this allows me to have the GOLD maps also on the web portal, but I can't make a comparison, but if my tests are good, the OSM ones, I'll continue like this. Since I travel a lot by motorcycle (an average of 30,000 km per year), I've had the opportunity to see many errors while navigating the routes created with the web planner, but I think these are due to the Here maps, but I'm not sure because I should have created the route directly on the Zumo, but during the trip, it's not always possible.
                      Giuseppe Marino
                      Giuseppe Marino
                      Alex reds
                      Alex reds
                        13.8k
                        1.1k
                      • Carpuride scherm vast
                        1.2k
                      • Camperroutes
                        De Ploey Georges
                        De Ploey Georges
                        Philip Verbeek
                        Philip Verbeek
                      • Latest version of the App?
                      • HERE maps updates
