  3. Overight Stay
Overight Stay
3 Posts 3 Posters 1.1k Views 2 Watching
  • Bummerl Munich
    Bummerl Munich
    Bummerl Munich
    Hi There!
    I am searching for a function to plan an e.g. 14-day trip.
    To better see the daily distance I am looking for a function comparable to "overnight stay" which resets the daily distance so that I can see the planned driving time per day. To make one route by day is a bit complex (e.g. I have to set starting point for every day. Used the search function - did I miss something?
    Thanks in advance!
    • Reinhard-32
      Reinhard-32
      Reinhard-32
      You can planing a roughly route over the 14 days with few waypoint. At the left hand side in the waypoint list you can see the driving time between the waypoints. If finished you can split the route at the desired waypoints. The endpoint from the first segment is the starting point for the second segment an so on. Afterwards make the fine tuning for each route segment.
      Kindly regards
      Reinhard
      Montana 700i and Mac
      • HABVEN aka MrMRA
        @Bummerl-Munich
        You can make your starting point a favorite, so you can select this from the menu on the left site.
        Create a folder where you store the routes
        Create a new route using start date and time
        Use via-points where you want to stop ( if you are using MRA Navigation or a Zumo XT)
        Use pause timing so the total duration of your route is calculated
        Reinhard-32
        Reinhard-32
        Bummerl Munich
        Bummerl Munich
        • Kaart niet zichtbaar
          Bé Jeuring
          Bé Jeuring
        • Xpert overlay not clear
        • Google maps
          Ed Bos 0
          Ed Bos 0
          Corrado Miniati 0
          Corrado Miniati 0
        • Trains like Ferries?
          Corrado Miniati 0
          Corrado Miniati 0
