  4. Route differences since new update!
23 Posts 7 Posters 8.5k Views 4 Watching
  • stuart marritt
    stuart marritt
    stuart marritt
    I have just picked the same end point as I had the issue on but I am at my home so is a different start location but it now gives me 3 routes
    • BMcG
      in original screenshots it looked like your phone was in landscape mode
      latest is in portrait mode
      it is a longshot but somehow somwhere it looks like the original graphic choice screen had a glitch/error & only showed the 2 choices & not your optimal first choice
      stuart marritt 1 Reply Last reply
      • BMcG BMcG
        stuart marritt
        stuart marritt
        stuart marritt
        @Brian-McG for reference here is the same in landscape
        Although I took the original in landscape it was doing the same in portrait too.
        • BMcG
          wrote on last edited by BMcG
          sorry I have no idea how the choice screen can glitch to show only 2 options instead of 3
          I will leave that question/answer to someone with a bit more knowledge
          best of luck
            Works as expected so to see.
            My reasoning before would be correct then it being a one time thing due to a mistiming at HERE calculations.
            The orientation has no effect, reloading does as it will recalculate yielding 1, 2 or 3 routes again based on the moment. Usually quite consistent.
              stuart marritt
              stuart marritt
              stuart marritt
              @Corjan-Meijerink Yes looks as though it was a one time thing!
              I will keep an eye on it and report back if it happens again
              • stuart marritt
                stuart marritt
                stuart marritt
                Just want to bring this back up again!
                Last night I was now no longer get the 3 route options and clicking on the different levels of windyness was showing me almost the same routes!
                Also it was trying to keep me on the fast straight roads which is the ones I was trying to avoid no matter what settings I used
                Is there some issues with the planner/scenic route when trying to do point A to Point B?
                • RainerT
                  RainerT
                  RainerT
                  When planning my routes on the computer, it often happens that Here® simply refuses to take a certain road.
                  This has often irritated or annoyed me.
                  The reason is almost always that part of the route is marked as closed or similar in Here. Unfortunately, this can only be seen when zooming in significantly and when the traffic layer is active.
                  Therefore, turning off traffic-aware routing would be an option when driving. However, this is not possible when planning, as the route is simply not feasible.
                  RT
                  • RainerT RainerT
                    RT
                    @Rainer-Treichel Hi Rainer. This has nothing to do with the update. Its simply how planning works. You're right with the conclusion that turning on the traffic layer gives you insite. Of you're shure that the obstruction is not a problem you can solve that with the Offroad Jeep sign so that piece will be ignored
                    • RainerT
                      RainerT
                      RainerT
                      Yo are right, nothing to do with the update.
                      RT
                      stuart marritt
                      stuart marritt
                      RainerT
                      RainerT
                        Hanza 0
                        Hanza 0
                        Giancarlo e
                        Giancarlo e
                      • Startpunt wijzigen
                        Ad V
                        Ad V
                        Ed van Klink
                        Ed van Klink
                      • Route exporteren uit beta
                      • Vrienden toevoegen
