  3. [Web] Announcements
  4. Scenic routing & RouteXpert library improvements
32 Posts 18 Posters 24.8k Views 8 Watching
  • Edwin_M Offline
    Edwin_M Offline
    Edwin_M
    Te vroeg gejuichd, stap op motor. Klik rondrit. Weer zelfde meldingen. Geforceerd afsluiten en opnieuw, geen verschil
    • Edwin_M Offline
      Edwin_M Offline
      Edwin_M
      #24
      When I finally got it going.. It came up with route 4 times longer then requested
      • Edwin_M Edwin_M
        Rob Verhoeff Offline
        @Edwin_M said in Scenic routing & RouteXpert library improvements:
        Daar moeten de dev's zeker nog wat tweaken. Ze hebben deze al in het vizier.
        That definitely still needs to be — and is being — tweaked by the devs!
        • stuart marritt Offline
          stuart marritt
          Trying to do a scenic route from my home to a location all I get is this?
          • AWDC LAO Offline
            AWDC LAO Offline
            BRAVO !
            • Edwin_M Offline
              Edwin_M Offline
              Edwin_M
              I did a few tests just now. Works a lot better. Distance ok and speed of generation was much faster
              • Corjan Meijerink Offline
                Indeed fixed the big OSM issue. Unfortunately the new higher quality route generation has been undone for now. Back up soon again! But the big fire has been extinguished 🙂
                • Bouke Ent Offline
                  Bouke Ent Offline
                  • iain.gardengmail.com Offline
                    What has happened to the twisty vs winding and high altitude vs low altitude options?
                    • Con Hennekens Offline
                      They have been depricated / automated. Thereby the route generator automatically takes into consideration roads that have been used by RX routes. I am not sure if the new Scenic roads layer is also incorporated, but I think yes.
                      stuart marritt
                      stuart marritt
                      Edwin_M
                      Edwin_M
                      Albert van den Elsen
                      Tony 13
                      Tony 13
                      MarcM
                      MarcM
                      Ralph c
                      Ralph c
                      James Lewington
                      James Lewington
                      • Duur van de route klopt niet
                      • Gidday from New Zealand.
                        Bull Tahr k 0
                        Bull Tahr k 0
                      • Beeld loopt achter
                        Maarten van de Wijdeven
                        Steve Jarrell
                        Steve Jarrell
                        28.3k
                      • Traject controle
