  3. [Web] Announcements
  4. Scenic routing & RouteXpert library improvements
32 Posts 18 Posters 26.8k Views 8 Watching
    Fantastisch. Eerst kwam de GPS shop uit Notter met de motorkaart voor de Garmin, speciaal voor motorrijders. En nu komen jullie met iets soortgelijks. Echt vergelijkbaar. Dit maakt alles nog weer mooier!
    Fantastic. First came the GPS shop from Notter with the motorcycle map for the Garmin, especially for motorcyclists. And now you come up with something similar. Really similar. This makes everything even more beautiful!
    • Edwin_M
      Edwin_M
      Edwin_M
      Te vroeg gejuichd, stap op motor. Klik rondrit. Weer zelfde meldingen. Geforceerd afsluiten en opnieuw, geen verschil
      • Edwin_M
        Edwin_M
        Edwin_M
        #24
        When I finally got it going.. It came up with route 4 times longer then requested
        • Edwin_M Edwin_M
          @Edwin_M said in Scenic routing & RouteXpert library improvements:
          Daar moeten de dev's zeker nog wat tweaken. Ze hebben deze al in het vizier.
          That definitely still needs to be — and is being — tweaked by the devs!
          • stuart marritt
            stuart marritt
            stuart marritt
            Trying to do a scenic route from my home to a location all I get is this?
            • AWDC LAO
              BRAVO !
              • Edwin_M
                Edwin_M
                Edwin_M
                I did a few tests just now. Works a lot better. Distance ok and speed of generation was much faster
                  Indeed fixed the big OSM issue. Unfortunately the new higher quality route generation has been undone for now. Back up soon again! But the big fire has been extinguished 🙂
                  • Bouke Ent
                    • iain.gardengmail.com
                      What has happened to the twisty vs winding and high altitude vs low altitude options?
                      • MotoCon
                        They have been depricated / automated. Thereby the route generator automatically takes into consideration roads that have been used by RX routes. I am not sure if the new Scenic roads layer is also incorporated, but I think yes.
                        Edwin_M
                        Edwin_M
                        Albert van den Elsen
                        Tony 13
                        Tony 13
                        stuart marritt
                        stuart marritt
                        MarcM
                        MarcM
                        Ralph c
                        Ralph c
                        James Lewington
                        James Lewington
                          TomOnTour
                          TomOnTour
                        • Pay for beta?
                        • Live payments enabled
                        • Maps Michelin
                          LE DIZES Freddy
                          LE DIZES Freddy
                          1.1k
                          Brett Bartick
                          Brett Bartick
                          TomOnTour
                          TomOnTour
                        • import in beta-mra failed
