  4. Herberekenen route
Herberekenen route
17 Posts 5 Posters 3.4k Views 2 Watching
  • henry van den belt
    henry van den belt
    henry van den belt
    wrote on last edited by henry van den belt
    Het herberekenen van de route is problematisch.
    Wanneer ik navigeer met mra en ik kies er voor om een andere route te nemen dan de mra navigatie voorgesteld heeft dan wordt er geen nieuwe route berekend.
    Ik moet dan de huidige route annuleren en opnieuw invoeren.
    Route herberekenen staat aan
    Erg vervelend
    Peter Zehentreiter Con Hennekens 2 Replies Last reply
    • henry van den belt henry van den belt
      Erg vervelend
      @henry-van-den-belt Have you enabled automatic recalculation in the settings?
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
      henry van den belt 1 Reply Last reply
        henry van den belt
        henry van den belt
        henry van den belt
        @Peter-Zehentreiter it's on.
          @henry-van-den-belt Can you explain in more detail when the problem occurs? Are you following a planned route with points, or are you just entering the start and destination? Can you make the route you drove public so we can see what's causing the error?
          BMW R 1250 GS
          DMD-NOR7E 7"
          SPC Universal mount
          Sena SLR 3
          Sena 50 R
            henry van den belt
            henry van den belt
            henry van den belt
            @Peter-Zehentreiter
            I am navigating from home to an adress.
            The routeplanner sends me through the city center so i decide to not follow directions but drive another way.
            The routeplanner does not recalculate. My internet is 100%.
            The location arrow on the screen follows my location but the navigation arrow dissapears
              @Peter-Zehentreiter
              @henry-van-den-belt When entering your destination, did you choose a selection of winding routes, or are you taking the fastest route?
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Sena SLR 3
              Sena 50 R
                henry van den belt
                henry van den belt
                The fastest
                  The fastest
                  @henry-van-den-belt @Nick Carthew
                  I'm sorry, then I can't imagine what could be the reason, maybe Nick can help us here.
                  BMW R 1250 GS
                  DMD-NOR7E 7"
                  SPC Universal mount
                  Sena SLR 3
                  Sena 50 R
                    Erg vervelend
                    @henry-van-den-belt, dat is erg ongebruikelijk... Je zegt dat route herberekening aan staat. Misschien flauw maar weet je dat zeker? Heb je een screenshot van het moment waar dit gebeurd?
                      henry van den belt
                      henry van den belt
                        henry van den belt
                        henry van den belt
                        Helaas geen screenshot van het moment zelf.
                        Op de terugweg had ik een ander probleem. Toen bleek de herberekening wel te werken, maar stuurde de navigatie mij steeds terug naar het punt waar ik de organieke route had verlaten.
                        Alsof ik via dat ene overgeslagen punt moest rijden. De navigatie bleef mij kilometers lang terugsturen totdat ik op een gegeven moment verderop weer op de route kwam. Toen pikte de navigatie de route weer op
                        • Marinus van Deudekom
                          Met een A B route is dat wel wat het systeem zou moeten doen op basis van je instellingen. Als je van die instellingen af wil wijken, doe je dat waarschijnlijk omdat je daar bekend bent. De mens is Gelukkig toch nog slimmer
                            Voor een A naar B route terug sturen naar het punt waar je afgeweken bent, is normaal gedrag?
                            Het is veel normaler dat de navigatie mee je kijkt en tegelijkertijd de originele route ook volgt om te kijken waar je verderop weer op de route kan komen.
                              @M.-Schrijver je mag er anders naar kijken omdat jij dat zo ziet. Ik.leg alleen uit hoe het systeem werkt, het probeert je 3 x terug te sturen naar de aanvankelijke route die was gemaakt aan de hand van JOUW voorkeuren. Als je daar vanaf wijkt zal het proberen JOUW voorkeuren te volgen. 3 x en dan een alternatief zoeken, niet mee eens, simpel selecteer andere voorkeuren
                                Een A naar B route is heel wat anders dan een van te voren geplande route in een routeplanner.
                                Daarnaast dat iets op een bepaalde manier bedacht is, wil niet zeggen dat dit ook een juiste werkwijze is.
                                Als ik een adres invoer (een typische A naar B). Verwacht ik dat ik zo snel mogelijk of via de kortste weg (wat je ook gekozen mag hebben), naar het eindpunt gestuurd wordt en niet onderweg rondjes aan draaien ben omdat ik iets gemist zou hebben.
                                Bij geplande route uit routeplanner wordt er van je verwacht dat je de route volgt. En dan kan het inderdaad voorkomen dat je terug gestuurd wordt.
                                  @M.-Schrijver of nog simpeler, volg gewoon de instructies
                                    @M.-Schrijver said in Herberekenen route:
                                    Dat klopt, en zo werkt het ook. Bij een directe route (dus zonder kronkel-opties) naar één bestemming is er ook helemaal geen track of routepunt waarnaar je teruggestuurd zou kunnen worden. Wat het vreemde gedrag in @henry-van-den-belt zijn geval veroorzaakt heeft, geen idee. Ik zou wel willen weten of in zijn geval dit gedrag herhaaldelijk voorkomt, of dat het bij die ene keer is gebleven.
                                    henry van den belt
                                    henry van den belt
                                    • Beta Navigation V.6
                                    • Route overlay
                                    • Lock route editing
                                      Albert van den Elsen
                                    • Group ride
                                    • Laat bijbehorende POI zien
                                    • Save locations/positions
                                    • How do you navigate off-road routes with Next?
