  4. MRA MyRoute app version 4.3.9 - 395 - only shows a very much zoomed in route.
20 Posts 6 Posters 1.7k Views 6 Watching
  • Inge Bakermansundefined Offline
    Inge Bakermans
    Dear web developers,
    I currently am having issues on my Samsung tab A9+, Android version 14, with One UI 6.1. Since about a week when I drive a track all I see is a very much zoomed in route (am using the tablet in my campervan). I think it has to do with the latest update, since before I had a nice overview of the route/ road when driving. Now I do not even see an upcoming roundabout until I am pretty much on it. When driving mountains, it is very nice to have a bit of a road view of what is coming up - turnwise and such.
    I have not changed any settings to cause this very much zoomed in sight of my route. When I manually zoom out, it only stays like that for a few seconds before it goes back to the zoomed in state.
    Is there anything I can do to correct this, or is this a flaw in the latest update?
    • Stanisławundefined Offline
      I would also like to see more in the dynamic view mode. Currently, about a third of the screen in horizontal orientation is lost for the sky. I'm afraid the only solution for now is the top view mode where you can select another zoom.
        We fixed some zoom issues in this update.
        What are your visual settings? Perhaps it is a good idea to check them / reconfigure it!
        Inge Bakermansundefined 1 Reply Last reply
          @Stanisław if that’s the case, check your tilt configuration. Might be a good idea to lower it. Due to a fixed issue your own configuration might not be suitable anymore.
            Will be tested this weekend 🙂
              Inge Bakermans
              @Corjan-Meijerink I know you did tackle some issues, however since the update my zoom is off.
              How should I set the visual settings according to you? For they were fine before the update.
              • Inge Bakermansundefined Inge Bakermans
                Rob Verhoeffundefined Offline
                @Inge-Bakermans said in MRA MyRoute app version 4.3.9 - 395 - only shows a very much zoomed in route.:
                Go to your app-setting!
                Menubars upper left corner > Account upper right corner > Navigation settings > Map layer > adjust Default zoom correction and/or Tilt correction.
                  Inge Bakermans
                  Did check and standard zoom correction is 0,0 - tiltcorrection is also 0,0.
                  This should not cause the route to be way too much zoomed in, right?
                    @Inge-Bakermans Yep, that should show plenty of map and almost no tilt.
                      Perhaps share a screenshot of what you are seeing and verify if you're not driving in the topdown modus (with fixed zoom).
                        In my case the tiltcorrection was +8 so it could be wrong setting 🙂
                          Inge Bakermans
                          Will try to do that Corjan.
                          Drove with settings at 0 and still very little zoom.
                          Will take a photo with my phone of the tablet and post it.
                            Inge Bakermans
                            How do I check the not driving in fixed zoom btw?
                              @Inge-Bakermans Press the compass sign
                              "during navigation mode" and watch the pop up showing the current mode.Screenshot_20250530-131816.png Screenshot_20250530-131829.png Screenshot_20250530-131843.png
                              BMW R 1250 GS
                              BMW Connected Ride Cradle
                              SPC Universal mount
                              Motorola Edge 40
                              Sena SLR 3
                              Sena 50 R
                                I have done about 1 kkm during the weekend, with the settings tilt correction = 0, it seems ok now - about 300 m ahead visible in the dynamic mode. I use 8'' tablet in horizontal view. Thanks @Corjan-Meijerink !
                                  Inge Bakermans
                                  Corjan, dit is wat ik zie.
                                    Inge Bakermans
                                    Peter thanks for the photos - will try the pressing of the compass tomorrow when driving.
                                    Have set it for now on dynamic camera on the tablet - landscape.
                                      @Inge-Bakermans that for sure is not dynamic. Indeed tap the compass to switch to it 🙂
                                        @Inge-Bakermans, Your opening post was in English, so I will continue in English. What is it exactly that is not good on your screenshot?
                                          Inge Bakermans
                                          Am on the road so my apologies for the late reply. have indeed been tapping the compass and have it now way more zommed out - just like I like it. Thanks guys for the help.
                                          Inge Bakermans
                                          Stanisławundefined
                                            Nomko Nomdenundefined
                                            Nomko Nomden
                                          • MRA E-Learning
                                          • WIJZIGINGEN IN ROUTE
                                            Boštjan Kreutzundefined
                                            Boštjan Kreutz
                                          • MRA working great
                                          • Can't type in (Route-information) (Description )
                                          • Start niet op, blijft hangen
                                            1.3k
                                          • VERANDERING ROUTE NA AFSLUITEN
