  4. What to use to plan a new route ?
7 Posts 4 Posters 2.4k Views 3 Watching
  • Joce-Doubs
    Joce-Doubs
    Joce-Doubs
    I prepare my routes on MRA web, and navigate on MRA Nav.
    What type of calcul do I use on the net (Garmin, TomTom or Open Street Map) ?
    Can I use every map ?
    Thanks
    Adrian Avram TomOnTour 2 Replies Last reply
    • Kenny Thierens
      Kenny Thierens
      Kenny Thierens
      If you navigate with MRA, make your routes with the "Here" map service (pic 1).
      It doesn't matter which map layer you want to use, personal preference (pic 2).
      '07 BMW R1200RT
      DMD² T865x tablet
      Silverfox C1 controller
      Samsung S24+
      Cardo Spirit HD headset
      • Joce-Doubs Joce-Doubs
        Thanks
        @Joce-Doubs Depends what you are using for navigation, a GPS NAV device or MRA Next on your phone.
        Adrian
          Thanks
          TomOnTour
          TomOnTour
          TomOnTour
          @Joce-Doubs For the pure planning excercise on the web you can use any map you want. You just need to keep in mind, that MRA Next (The Nav APP) is always using the Here-maps and the related routing algorithem. If you plan with any "non-Here" map on the web, you should finish your planning and use the compare feature to see, if the route takes the same shape, when you will use a Here map.
          If you find any differences, then you should change the route to fit to your originally planned layout.
          I hope I did not totally confuse you now. 🙂
          • Joce-Doubs
            Joce-Doubs
            Joce-Doubs
            OK, thanks to all. I navigate with MyRoute Nav on a Carpe Iter.
            I actually prepare a 6 months roundtrip to Saoudi Arabia, Oman, Iran, ...
            So, I'm training on this app because it allows to have a lot of informations. On my previous trips, I used Garmin Zumo because this app was not so great
              @Joce-Doubs then you will have to plan your routes using the Here map.
              Adrian
              • Joce-Doubs
                Joce-Doubs
                Joce-Doubs
                thank you
                TomOnTour
                TomOnTour
                Joce-Doubs
                Joce-Doubs
                Kenny Thierens
                Kenny Thierens
                • Live tracking
                  eyal 0
                  eyal 0
                • Routing issue
                • Bar Buttons problems
                • Compare providers error
                • Overlapping routes
                  peha
                  peha
