  3. [Beta] Announcements
  4. New beta! 4.3.9 (391)
22 Posts 12 Posters 317 Views 7 Watching
  • CD130undefined Offline
    Thanks for the update and look forward to the “major overhaul of the app”. Good luck!!
      Hi all! 👋
      Yes, it has been a long time since there was an update. Normally when I say that it's only true because we have so many. Now it's actually just quite a while since the last one.
      We are working on a major overhaul of the app. Completely revamping the experience and ensuring the app feels premium. This together with some core architecture improvements. It's just a lot of work and takes a while 💪
      That said, the app as it is definitely does operate quite well! Obviously there are some issues and this update aims to tackle that.
      Audio stability
      There were quite some issues where users reported that sometimes the selected voice would not work, there wouldn't be any audio or that it would be very low. Now there is the possibility that it is a user error but we've also identified some problems on our side 😉 We hope the audio has significantly improved in this version!
      MapBox update
      Map what? It's the engine used to show the maps when you launch the app. We've updated this to the latest version which will definitely contribute to the app stability. We are however curious if nobody has issues with this update. If you don't see any maps when launching the app, it's because of this. Don't worry, just let us know ❤
      Minimum iOS version
      You are now required to have at least iOS 14 - no worries as all phones supporting iOS 13 (the previous requirement) also support iOS 14.
      Minor changes
      • SilverFox C1 support
      • Fixed some typo's
      • Resolved 2D HERE maps not loading on start screen
      • Landscape modus shows option to recalculate route when you've disabled automatic recalculation and you deviated from the route
      • Fullscreen mode actually dismissed correctly when exiting navigation (only applies when you've enabled fullscreen mode)
      • Resolved position indicator alignment issue when switching between apps (we think)
      Now that's it really 😃
      We are working incredibly hard on a major app update and besides that we are also improving our scenic routing algorithm / server and as nice extra we want to add custom overlay maps to help you plan by showing where scenic / RouteXpert routes are 😏
      All the best,
      Corjan
      Wonderful and thank you very much for that 👋!!️
        Hi all! 👋
        Audio stability
        MapBox update
        Minimum iOS version
        Minor changes
        • Fixed some typo's
        All the best,
        Corjan
        Arjan de Vriesundefined Offline
        Arjan de Vries
        @Corjan-Meijerink geweldig! Jullie blijven me steeds verbazen! Keep up the good works.
        Vraag: Een poosje geleden hebben we het ook gehad over de integratie van de dmd remote2. Komt deze ook binnenkort in een update zodat deze samenwerkt met MRA?
        Het mooie aan de dmd2 is de joystick die 360 graden kan werken. Silverfox (bij mijn weten) kan dat niet.
          Hi all! 👋
          Audio stability
          MapBox update
          Minimum iOS version
          Minor changes
          • Fixed some typo's
          All the best,
          Corjan
          @Corjan-Meijerink it’s Out on Ios
            Hi all! 👋
            Audio stability
            MapBox update
            Minimum iOS version
            Minor changes
            • Fixed some typo's
            All the best,
            Corjan
            Ruud Schoutenundefined Offline
            Ruud Schouten
            @Corjan-Meijerink Super ! 🙂 dank voor al het harde werk!
              I just did an update on Android but it appears to have updated to 4.3.8 -386
                @RetiredWingMan Beta for Android is still processing 🙂
                DerRoteBlitzundefined 1 Reply Last reply
                  DerRoteBlitzundefined Offline
                  DerRoteBlitz
                  @Corjan-Meijerink Hi, Android version is now available.
                  white.mouseundefined 1 Reply Last reply
                  • DerRoteBlitzundefined DerRoteBlitz
                    white.mouseundefined Offline
                    @DerRoteBlitz Still no android update available for me!
                      @white-mouse misschien nog een keer proberen. Bij mij doet hij het wel
                        @Marinus-van-Deudekom
                        Net weer even gekeken in de appstore maar hij komt nog niet als update in de lijst voor. Alle programma's zouden "up to date zijn"!
                        Toch is MRA nog de 4.3.8 -386 versie
                        Maar . . . als ik MRA vervolgens handmatig opzoek in de Appstore, dan krijg ik ineens wel de mogelijkheid om te updaten. En inderdaad nu heb ik versie 439 - 391!
                        Vreemd. Zo heb ik het nog niet eerder gehad! Maar goed, dinsdag eens even gaan proberen.
                        Arjan de Vriesundefined Marinus van Deudekomundefined 2 Replies Last reply
                          Arjan de Vries
                          @white-mouse Ik zie hem nog niet in de app store. Ook niet als ik handmatig naar de app store ga. Nog steeds 4.3.8
                          Arjan de Vriesundefined 1 Reply Last reply
                            Gisteren een route gereden die ik jaren geleden in Basecamp heb gemaakt: Veel teveel routepunten en de meeste punten direct na de kruising geplaatst.
                            Wat mij opviel is dat, op één hand te tellen na, alle instructies werden uitgesproken. Een tijdje geleden had dit qua instructies een hele stille route geweest 😋
                            Weet niet of het toeval is of dat er achter de schermen actief iets aan is verbeterd, maar ik was er gisteren erg blij mee 👍
                            Verder geen bijzonderheden. App deed het prima op iOS.
                              @white-mouse in mijn telefoon werd hij automatisch voorzien van de juiste Update
                              Op mijn Thork tablet nadat ik updates had gestuurd.
                              Voor de zekerheid, het is een Bèta update dus misschien dat dat bij jullie veroorzaakt dat het niet automatisch gaat.
                              Jullie zijn toch ook Beta testers
                              • Arjan de Vriesundefined Arjan de Vries
                                Arjan de Vries
                                @Arjan-de-Vries oepsie… bèta…. Ik ben geen tester. Nog even geduld dus.
                                  @Arjan-de-Vries, Jij hebt toegang gekregen tot de beta-forums, dus je zou wel beta-tester kunnen zijn, als je dat wilt 😉 . Even aanvragen via een support ticket. Je loopt wel wat meer risico op bugjes natuurlijk.
                                  • Jörgenundefined Offline
                                    Hi, can we please agree to continue the answers in the language as it starts in the first post?
                                    Using the translator again and again is tedious.
                                    Thank you!
                                      I leave Google Translate on all the time so to be honest, a lot of the time I don't even realise the language is not English.
                                      • Jörgenundefined Jörgen
                                        Thank you!
                                        @Jörgen You're an iOS user, right? With Safari you can translate the entire page into your native language. Ideal 👍
                                        • Lluis Arasanzundefined Offline
                                          I agree with @Jörgen,
                                          I don't like to use a translator all the time on my device. I can read and write in Spanish and Catalan, but, of course, in international forums, I allways write in English.
                                          I think is an educational reason against the rest or users.
                                          Tambien puedo escribir en español, por supuesto, pero que necesidad hay de empezar a utilizar traductores?
                                          • BMW F750GS
                                          RetiredWingManundefined
                                          CD130undefined
                                          Arjan de Vries
                                          DerRoteBlitz
                                          Ruud Schouten
                                            2.9k
                                          • Crashes na update
                                            Jan Weerheimundefined
                                            Jan Weerheim
                                          • Doe ik iets verkeerd of...
                                          • Duizend bochten
                                            Herman Veldhuizenundefined
