  3. [Beta] Announcements
  4. New beta! 4.3.9 (391)
22 Posts 12 Posters 317 Views 7 Watching
  • Corjan Meijerink Online
    Hi all! 👋
    Yes, it has been a long time since there was an update. Normally when I say that it's only true because we have so many. Now it's actually just quite a while since the last one.
    We are working on a major overhaul of the app. Completely revamping the experience and ensuring the app feels premium. This together with some core architecture improvements. It's just a lot of work and takes a while 💪
    That said, the app as it is definitely does operate quite well! Obviously there are some issues and this update aims to tackle that.
    Audio stability
    There were quite some issues where users reported that sometimes the selected voice would not work, there wouldn't be any audio or that it would be very low. Now there is the possibility that it is a user error but we've also identified some problems on our side 😉 We hope the audio has significantly improved in this version!
    MapBox update
    Map what? It's the engine used to show the maps when you launch the app. We've updated this to the latest version which will definitely contribute to the app stability. We are however curious if nobody has issues with this update. If you don't see any maps when launching the app, it's because of this. Don't worry, just let us know ❤
    Minimum iOS version
    You are now required to have at least iOS 14 - no worries as all phones supporting iOS 13 (the previous requirement) also support iOS 14.
    Minor changes
    • SilverFox C1 support
    • Fixed some typo's
    • Resolved 2D HERE maps not loading on start screen
    • Landscape modus shows option to recalculate route when you've disabled automatic recalculation and you deviated from the route
    • Fullscreen mode actually dismissed correctly when exiting navigation (only applies when you've enabled fullscreen mode)
    • Resolved position indicator alignment issue when switching between apps (we think)
    Now that's it really 😃
    We are working incredibly hard on a major app update and besides that we are also improving our scenic routing algorithm / server and as nice extra we want to add custom overlay maps to help you plan by showing where scenic / RouteXpert routes are 😏
    All the best,
    Corjan
    Hubert Thoring Arjan de Vries Marinus van Deudekom Ruud Schouten 4 Replies Last reply
    • CD130 Offline
      CD130 Offline
      Thanks for the update and look forward to the “major overhaul of the app”. Good luck!!
        Hi all! 👋
        Audio stability
        MapBox update
        Minimum iOS version
        Minor changes
        • Fixed some typo's
        All the best,
        Corjan
        Hubert Thoring Offline
        Wonderful and thank you very much for that 👋!!️
        iPad 9. Gen iOS 26.6/ iPhone 16e iOS 26.6/ Navi iPhone Xr iOS 18.7.10 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
          Hi all! 👋
          Audio stability
          MapBox update
          Minimum iOS version
          Minor changes
          • Fixed some typo's
          All the best,
          Corjan
          Arjan de Vries Offline
          Arjan de Vries
          @Corjan-Meijerink geweldig! Jullie blijven me steeds verbazen! Keep up the good works.
          Vraag: Een poosje geleden hebben we het ook gehad over de integratie van de dmd remote2. Komt deze ook binnenkort in een update zodat deze samenwerkt met MRA?
          Het mooie aan de dmd2 is de joystick die 360 graden kan werken. Silverfox (bij mijn weten) kan dat niet.
            Hi all! 👋
            Audio stability
            MapBox update
            Minimum iOS version
            Minor changes
            • Fixed some typo's
            All the best,
            Corjan
            Marinus van Deudekom Offline
            @Corjan-Meijerink it’s Out on Ios
              Hi all! 👋
              Audio stability
              MapBox update
              Minimum iOS version
              Minor changes
              • Fixed some typo's
              All the best,
              Corjan
              Ruud Schouten Offline
              Ruud Schouten
              @Corjan-Meijerink Super ! 🙂 dank voor al het harde werk!
              • RetiredWingMan Online
                I just did an update on Android but it appears to have updated to 4.3.8 -386
                  @RetiredWingMan Beta for Android is still processing 🙂
                  DerRoteBlitz 1 Reply Last reply
                    DerRoteBlitz Offline
                    DerRoteBlitz
                    @Corjan-Meijerink Hi, Android version is now available.
                    white.mouse 1 Reply Last reply
                    • DerRoteBlitz DerRoteBlitz
                      white.mouse Offline
                      white.mouse Offline
                      @DerRoteBlitz Still no android update available for me!
                      • white.mouse white.mouse
                        @white-mouse misschien nog een keer proberen. Bij mij doet hij het wel
                        • white.mouse Offline
                          white.mouse Offline
                          @Marinus-van-Deudekom
                          Net weer even gekeken in de appstore maar hij komt nog niet als update in de lijst voor. Alle programma's zouden "up to date zijn"!
                          Toch is MRA nog de 4.3.8 -386 versie
                          Maar . . . als ik MRA vervolgens handmatig opzoek in de Appstore, dan krijg ik ineens wel de mogelijkheid om te updaten. En inderdaad nu heb ik versie 439 - 391!
                          Vreemd. Zo heb ik het nog niet eerder gehad! Maar goed, dinsdag eens even gaan proberen.
                          Arjan de Vries Marinus van Deudekom 2 Replies Last reply
                            Arjan de Vries
                            @white-mouse Ik zie hem nog niet in de app store. Ook niet als ik handmatig naar de app store ga. Nog steeds 4.3.8
                            Arjan de Vries 1 Reply Last reply
                            • CD130 Offline
                              CD130 Offline
                              Gisteren een route gereden die ik jaren geleden in Basecamp heb gemaakt: Veel teveel routepunten en de meeste punten direct na de kruising geplaatst.
                              Wat mij opviel is dat, op één hand te tellen na, alle instructies werden uitgesproken. Een tijdje geleden had dit qua instructies een hele stille route geweest 😋
                              Weet niet of het toeval is of dat er achter de schermen actief iets aan is verbeterd, maar ik was er gisteren erg blij mee 👍
                              Verder geen bijzonderheden. App deed het prima op iOS.
                                @white-mouse in mijn telefoon werd hij automatisch voorzien van de juiste Update
                                Op mijn Thork tablet nadat ik updates had gestuurd.
                                Voor de zekerheid, het is een Bèta update dus misschien dat dat bij jullie veroorzaakt dat het niet automatisch gaat.
                                Jullie zijn toch ook Beta testers
                                  Arjan de Vries
                                  @Arjan-de-Vries oepsie… bèta…. Ik ben geen tester. Nog even geduld dus.
                                    @Arjan-de-Vries, Jij hebt toegang gekregen tot de beta-forums, dus je zou wel beta-tester kunnen zijn, als je dat wilt 😉 . Even aanvragen via een support ticket. Je loopt wel wat meer risico op bugjes natuurlijk.
                                    • Jörgen Offline
                                      Jörgen Offline
                                      Hi, can we please agree to continue the answers in the language as it starts in the first post?
                                      Using the translator again and again is tedious.
                                      Thank you!
                                      CD130 1 Reply Last reply
                                        I leave Google Translate on all the time so to be honest, a lot of the time I don't even realise the language is not English.
                                          Thank you!
                                          CD130 Offline
                                          CD130 Offline
                                          @Jörgen You're an iOS user, right? With Safari you can translate the entire page into your native language. Ideal 👍
                                          Arjan de Vries
                                          Arjan de Vries
                                          DerRoteBlitz
                                          DerRoteBlitz
                                          Ruud Schouten
                                          Ruud Schouten
                                            Don Stauffer
                                            Don Stauffer
                                            Peter Burch 1 0
                                            Peter Burch 1 0
                                          • Update 5.2.2 - Quick fix
                                            John
                                            John
                                            1.0k
                                            Huibertus
                                            Huibertus
                                          • No location in Android Auto ! App unusable !
