  4. Offline mode issue
Offline mode issue
9 Posts 4 Posters 2.7k Views 3 Watching
  • Steve Jarrell Offline
    Steve Jarrell
    I know that I must be doing something wrong, but I cannot get the offline mode to work properly. I do have the most current maps downloaded for the areas where I'll be traveling, and I have Offline Navigation enabled. I also have my routes synched to my device (DMD T865X).
    If I disconnect from the Internet I can see the map and route using the HERE map, but the resolution is very poor when I zoom in. Obviously the other maps don't work. If I establish my Internet connection and turn off Offline Navigation everything works properly, however the HERE map resolution is still very poor when zoomed in. All of the other maps appear just fine as long as I have an Internet connection and Offline Navigation disabled.
    I'm starting a 3 week trip tomorrow and this is the first time that I've tried offline navigation and I'm concerned about what's going to happen when I lose cell coverage.
    Thanks for your help!
    Steve
    Steve Jarrell
    Western North Carolina US
    2025 BMW R1300GS
    2025 Can-Am Spyder
    DMD T865-X 8" Tablet
    Garmin XT3
    Adrian Avram Steve Jarrell 2 Replies Last reply
    • Steve Jarrell Steve Jarrell
      Steve
      Adrian Avram Offline
      @Steve-Jarrell you are looking only at the front layout, and that requires internet.
      After going offline, go to your Routes, select the route and hit Navigate !
      Only then it will be opened in the Here offline maps from the phone !
      You cannot navigate using OSM or TomTom maps!
      I wish that they were replaced by Here (the offline maps downloaded into the phone !)
      Adrian
        Steve
        Steve Jarrell
        @Steve-Jarrell In doing a little more testing it seems like the problem is the latest version of the offline version of the maps that I just downloaded for my regions are very low quality when zoomed in. I'm using the United States maps for North Carolina, Vermont, New Hampshire, Maine and Massachusetts. If someone could confirm this I would appreciate it!
        Steve Jarrell
        2025 BMW R1300GS
        2025 Can-Am Spyder
        Garmin XT3
          Steve Jarrell
          Thanks! I was just opening the route and not selecting navigate!
          Steve Jarrell
          2025 BMW R1300GS
          2025 Can-Am Spyder
          Garmin XT3
          • Adrian Avram Adrian Avram
            Steve Jarrell
            @Adrian-Avram Just a couple of sentences in the documentation would be a huge help in understanding how the offline HERE maps work (and when they don't), and would have saved me several hours of experimenting (and frustration).
            A few things that I think need to be documented re: the offline maps:
            1. They only work when you're navigating, not when you just open a route to view it (when you're many miles away from your route that you want to view you don't want to choose navigate).
            2. If you select the HERE map when you're in online mode, MRA doesn't actually use the downloaded high resolution maps and the resolution is very poor. I'm not sure what HERE map MRA is using in this case but it's definitely not the hi-res downloaded maps as all of the other maps are of much higher quality.
            3. The HERE map selection ONLY works properly when you're offline, you have downloaded your maps and synched your routes, and then ONLY when you're navigating.
            To me this was very confusing as when I use the web based route planner I'm always using the HERE map selection, so I just assumed that the HERE map in the app should be the one that I should choose whether or not I'm online or offline.
            If I'm confused about 1-3 above hopefully someone will correct me. I'm here to learn!
            Thanks again for your help!!
            Steve
            Steve Jarrell
            2025 BMW R1300GS
            2025 Can-Am Spyder
            Garmin XT3
              Steve
              @Steve-Jarrell maybe @Corjan-Meijerink will do a change in the app, so we can use the offline maps downloaded into the phone instead of the online layers (OSM, TomTom, Here) which requires internet.
              Adrian
              • Corjan Meijerink Offline
                In the major update we are working on this issue will be one of the past 🙂
                Steve Cuttell Steve Jarrell 2 Replies Last reply
                  Steve Cuttell Offline
                  Steve Cuttell
                  @Corjan-Meijerink I too have just been through the same process as the OP trying to understand why the detailed offline map was only available when actually navigating. Good to hear that an update is planned.
                  Does this explain why I cannot search for a destination when offline? I cannot find any results when searching for a street name or postcode or hotel name for example when offline. Is this normal? If so then is this also being looked at in the update? Otherwise I do not understand how to search and find a new destination if offline which could be an important function when we have no mobile signal.
                    Steve Jarrell
                    @Corjan-Meijerink That will be AWESOME!
                    Steve Jarrell
                    2025 BMW R1300GS
                    2025 Can-Am Spyder
                    Garmin XT3
                    Steve Jarrell
                    Steve Jarrell
                    Steve Cuttell
                    Steve Cuttell
                    • Route Breakdown
                    • The slow death of Zumo...
                    • MRA Touring Romania Group
                    • I can't see Road Closures
                      Lary
                      Lary
