  4. Another day MyRoute-app screwed up My Route
52 Posts 6 Posters 32.6k Views 2 Watching
  • Ton Machielsen Offline
    Ton Machielsen
    Ha! Never seen that menu before!! Thanks!
      Ton Machielsen
      Any idea why I don’t get the waypoint hand and Skip Waypoint icon on the CarPlay? (see https://forum.myrouteapp.com/post/61333)
      Remember I am on a bike. I have the phone in my pocket and am navigating through the CarPlay device.
      • Ton Machielsen Ton Machielsen
        Marinus van Deudekom Offline
        @Ton-Machielsen Due to restrictions by Apple and Google the viapoint sign is NOT on Androis Auto and Carplay
        Ton Machielsen 1 Reply Last reply
          @Marinus-van-Deudekom
          Something to add to your comment.
          When waypoints are way off route/road and you're riding a route (not a track). How can MRA Navigation (or other navigation) hit those waypoints when they are not on the road or very close to the road.
          Those waypoints causes recalculations just because the waypoints are too far off-road.
          Ton Machielsen
          @M-Schrijver Is the “Navigate routes as tracks” option my solution?
            @M-Schrijver Understand. That’s why I am suggesting a radius for the waypoint hits. If you pass the waypoint within that distance the waypoint is considered as hit.
            richtea999 Offline
            richtea999 Offline
            #31
            @Ton-Machielsen said in Another day MyRoute-app screwed up My Route:
            That is a sensible suggestion - agreed, but I suspect the radius must change depending on the circumstances. Roads that are close together will require a smaller radius to be drawn by MRA, so basically, the radius info would just be telling you what you know you need to do anyway - i.e. drop the waypoints 'accurately'! 😁
              M. Schrijver Offline
              @Ton-Machielsen
              No. If you want route to be riden reliable. The route itself should be made reliable. A navigation cannot fix a badly made route.
                @M-Schrijver Where can I find this setting?
                @Ton-Machielsen, I guess this thread gives some "food for thought" 😉
                Great thread, that shows the power of an "old-fashioned" forum! 💪
                  @Ton-Machielsen
                  Ton Machielsen
                  @M-Schrijver said in Another day MyRoute-app screwed up My Route:
                  @Ton-Machielsen
                  Ok, i'll bite. Define "a badly made route".
                  My take is that if the app shows the route i want to ride, the app should follow that route.
                  What's your take?
                    Ton Machielsen
                    @Marinus-van-Deudekom said in Another day MyRoute-app screwed up My Route:
                    Meaning the "Skip Waypoint" icon is also not? So how do i skip waypoints? Stopping, taking my gloves off, taking my phone out of my pocket, click "Skip waypoint", dress up and continue?
                    Marinus van Deudekom M. Schrijver 3 Replies Last reply
                      @Ton-Machielsen yep unfortunately that's the case when using Android Auto or CarPlay.
                        @Ton-Machielsen
                        What's your take?
                        @Ton-Machielsen not completely true. As long as you stay within MRA its by design that MRA will save the day and keep you on the route, even if the route is not made correctly like in your example. However if you wanted to use that same route in a dedicated device like a Garmin XT you would be in for a real bad day with a messed up route.
                          Ton Machielsen
                          @Marinus-van-Deudekom Yeah, and that's where i am struggling, apparently. I was assuming that if MyRoute-app drew the correct route, even though my waypoints are besides the road, that the app would prioritise the route over the waypoints. Which is not the case from what i experience and read.
                          I guess i will have to either be VERY precise in where i put my waypoints or choose another app which is following a route (route app, remember, not waypoint app) instead of waypoints.
                            Ton Machielsen
                            Team!! Thanks for all the suggestions and bearing with my gripes and complaints. I am getting there. I must admit, apart from maybe two or three, all my waypoints were quite far away of the road i was planning to take. I have corrected them and re-uploaded the route here: https://www.myrouteapp.com/en/social/route/10719669 I hope the waypoints are positioned better now.
                            While doing this i think that a small fix (not being a programmer) could avoid this situation. I plan on the mobile app, not on the computer, and while correcting the waypoints i came up with two improvements:
                            1. When holding the waypoint and moving it, you can not actually see where you place it because your finger is right on top of the waypoint. And since precision is required, it would be helpful if the waypoint on the screen was a bit offset from the finger on the screen. Unless there are more efficient ways of moving a waypoint, of course.
                            2. When moving a waypoint, making it snap to the nearest road would be helpful as well. I think that when i double-tap a road a new waypoint is placed on the road. This function would be helpful while moving waypoints as well. Unless there are tricks like double-tap on the road and removing the other one would work as well. Haven't tried that yet.
                            Ideas?
                            And yes, again, i am getting there, i hope.
                            richtea999 Carl Lee 2 Replies Last reply
                              Ideas?
                              richtea999 Offline
                              richtea999 Offline
                              #40
                              @Ton-Machielsen
                              The revised route looks a lot better, Ton. 👍
                              I still advise you to place the start and end points on roads though, and maybe a few metres in the direction you're intending to set off / arrive from, just to guaranteee you pass through them. Especially the start one. 😉
                              On the improvements front, they're good suggestions, but here's one for you in the meantime (because they'll not happen fast, if ever):
                              1. Get a stylus. Something like a basic Wacom one is cheap, pleasant to use, and it's a pen as a bonus:
                                https://www.amazon.co.uk/Wacom-Universal-Ballpoint-Smartphones-Touchscreen/dp/B07YDX6Y24
                                Then you can see what you're doing under the stylus tip!
                              • richtea999 richtea999
                                @Ton-Machielsen
                                Ton Machielsen
                                @richtea999 I think I have an iPad somewhere. Let me try that.
                                  Ideas?
                                  Carl Lee Offline
                                  Carl Lee Offline
                                  Carl Lee
                                  @Ton-Machielsen If you are planning on the mobile app, there is a 'place waypoint' icon which is the + sign within a teardrop within a yellow circle bottom centre of the page. Use that for accuracy. If you still mess up, click on the waypoint and use the 'move' 4-arrows icon. All very simple on the iPhone, Android is possibly similar.
                                      Depends
                                      Viapoints (hand shape) must be skipped manually. So yes, stop, take your glove of and push on the button to skip a waypoint.
                                      Shapingpoint (dropplet shape) can be skipped automaticly. But this works only good if the shapingpoint is placed close enough or on the road. If you place your waypoints just somewhere on the map. The navigation can get confused what to do.
                                      If you use route as track without visible waypoints, there is nothing to skip.
                                      But strange things like riding on both sides of a highway or turn in a sidestreet and then turn back, can still be there in track just because you did place the routepoints not correct enough.
                                        @Ton-Machielsen, just to be clear about what @M-Schrijver means: Of course ALL waypoints (whether VIA or SHAPING points wil be automatically skipped once you actually HIT them. Your route will continu without manual intervention if you pass a VIA point. It is just that a VIA point will NOT be skipped automatically WITHOUT hitting it, like a shaping point does. 😉
                                          Ton Machielsen
                                          @Con-Hennekens So my goal is to create shaping points instead of via points. Any idea on how to do this on the mobile app? Because to me it looks like i can only create via points. Is that correct?
                                          Carl Lee
                                          Carl Lee
                                          Ton Machielsen
                                          Ton Machielsen
                                          • The slow death of Zumo...
                                            Arno van Lochem - Senior RX
                                            Carl Lee
                                            Carl Lee
                                          • Rejoining routes
                                            Karl-Heinz Schwendner
                                          • New Zealand Touring Group
