  4. Voice instructions doesn't work on Android
voice commands
7 Posts 3 Posters 1.5k Views 1 Watching
  • wiener30
    wiener30
    wiener30
    Trial testing of the App.
    Tried everything what I could find. TTS in the App and in phone settings is Google.
    Voice prompts and Waypoint notifications are switched on.
    The only case when is works is when restarting the App. It tells once "Next turn is ..." and then silence forever.
    Any ideas?
    • wiener30 wiener30
      Any ideas?
      @wiener30 witch phone are You using. Do You Connect it to an other délice, like Bluetooth communication 8n your helmen, or to a car system
      wiener30 1 Reply Last reply
        wiener30
        wiener30
        wiener30
        @Marinus-van-Deudekom The phone is OnePlus 12 with Android. It is connected with Bluetooth to the infotainment system of a car.
        • wiener30 wiener30
          @wiener30 Could you check if it runs OK whithout connecting it to the car and can you make a screenshot of the audiosettings in MRA
            wiener30
            wiener30
            wiener30
            Voice commands and warnings work if Bluetooth is switched off. So Bluetooth is an issue.
            Also, it is a mess with voices: in settings a male voice is selected, but instructions are issued by a female voice in a mixed English-German language.
            Quite positive impression is how stops are handled. It is clearly a strong point of the App. Also, route planning on mobile works quite well.
            Few more remarks. By route planning in mobile app, the Favorites as well as other predefined waypoints are not accessible. So all waypoints must be selected manually.
            Few times by starting navigation a yellow message was issued warning that navigation will be based on a track, not a route., despite that a route has been created. I don't understand what is the reason but in any case this is not what I wanted.
            • wiener30
              wiener30
              wiener30
              Will you fix the problem with Bluetooth on Android.
              Voice commands don't work, if Bluetooth is switched on. Works only if Bluetooth is swithced off.
              • Con Hennekens
                @wiener30, that certainly is no general problem. There would be many questions about it, if it was. For these exemplary questions it is probably best to enter a support ticket through https://www.myrouteapp.com/support
                wiener30
                wiener30
                • Live tracking
                  eyal 0
                  eyal 0
                • Routing issue
                • Bar Buttons problems
                • Compare providers error
                • Overlapping routes
