  4. Save as PDF: distance to next instruction
3 Posts 2 Posters 648 Views
  • Herko ter Horstundefined Offline
    An issue someone posted elsewhere made me aware that the contents of a PDF differ depending on which map you use. I didn't realise this earlier, but it makes sense of course.
    I primarily use the TomTom map when planning and I've noticed that the PDF generated from that map does not contain the distance to the next instruction, which makes it virtually useless to me. OSM has the same issue. Only when using the HERE map, each instruction contains the distance to the next situation.
    Sample from a PDF generated for a route planned on the HERE map:
    Sample from a PDF for the same route/instructions after switching to the TomTom map:
      @Herko-ter-Horst, I vaguely remember that the chosen language is also a thing in this. Like that for Dutch - OSM this is not shown, but for English - OSM it is, or vice versa. I am not in a position to try this. I don't remember exactly, but maybe you can try that.
        @Con-Hennekens Tried English when I originally posted, just tried Dutch now, same results for each of the maps (OSM, TomTom: no; HERE: yes).
        • back to old situation with 2 apps
        • A to B Routing incorrect behavior
          Bouke Entundefined
          Boštjan Kreutzundefined
          Boštjan Kreutz
        • Here kaart
        • Verwijderen van routes in eigen bibliotheek
          Lex.Kloet.RXundefined
          Lex.Kloet.RX
        • RideSleepRepeat – Your Biker Stays Across Europe
          Bouke Entundefined
        • Geen notificatie bij uitnodiging evenement
        • Basecamp-Kurviger Overlay!
