  4. Garmin Basecamp gpx to MRA - how?
12 Posts 4 Posters 3.1k Views 3 Watching
  • Gary Hargravesundefined Offline
    Gary Hargraves
    Hi all, apologies if this is the wrong place ot post this but I have been sent (ahead of a four day ride in southern Spain) four GPX files that have been created in Garmin Basecamp (i know, i know, how dare they?!!!). How do I import them into MRA in a working/readable/legable/navigable format? I have tried on my phone but the route/track doesn't snap to roads, it takes the most direct route between way points. Any help would be most welcome. Thanks a lot - Gary
    Mzokkundefined Carl Leeundefined 2 Replies Last reply
    • Carl Leeundefined Offline
      Carl Lee
      @Gary-Hargraves it should be possible to use the MRA website to click 'Upload' the Route-track GPX from wherever you have it stored on your PC. Then from memory, I think it might be 'Use' or convert to a route - or similar. Anyway, I've done it before so try that and see where it leads.
      • Gary Hargravesundefined Gary Hargraves
        Mzokkundefined Offline
        @Gary-Hargraves I often export files from basecamp and upload them to MRA route planner. They come into MRA and preserve the shaping points and waypoints (Garmin Speak) as waypoints and via points (MRA speak) perfectly and route as planned. In Basecamp check that you don't have the navigation mode set as direct.
        Or for the route properties
        This is the route designed in Basecamp imported into MRA
        Garry Davisundefined 1 Reply Last reply
          Carl Lee
          Gary Hargravesundefined 1 Reply Last reply
          • Mzokkundefined Mzokk
            Garry Davisundefined Offline
            Garry Davis
            @Mzokk This is very interesting. Could you explain just how you do it. I've got as far as the above, but I'm at a loss as to what's next to get it into MRA. Nice one. 👍 👍
            Mzokkundefined 1 Reply Last reply
            • Garry Davisundefined Garry Davis
              @Garry-Davis
              Step by step.
              1. Create Route
              2. Export route
              3. exported route
              4. Import Route into MRA
              1. Select File
              2. Open file in Routes.
              Now in MRA same route as Basecamp using the same roads.
              • Garry Davisundefined Offline
                Garry Davis
                wrote on last edited by Garry Davis
                @Mzokk
                Hi there Mzokk,
                Well I'll be buggered, ( Not literally I might add ) I've been using Basecamp for a long time now, and I never knew that could be done, I've got lots of routes in Basecamp, that I've always wanted to put into MRA, and now thanks to you, I can spend the next rainy day ( Won't have to wait too long in the UK will I ) transferring them over.
                Thanks again for coming up with solutions to my problems 😂😂👍👍
                  @Mzokk
                  Hi there Mzokk,
                  @Garry-Davis No issue. Basecamp and MRA Routeplanner are great tools. I use MRA a lot particularly when on tour as its handy for creating routes/amending routes on the fly without having to carry a device capable of running Basecamp. I still use basecamp for handling POI's and some track handling as Basecamp is the better tool for this compared to MRA.
                  • Carl Leeundefined Carl Lee
                    Gary Hargraves
                    @Carl-Lee thanks a lot Carl 🙂
                      Gary Hargraves
                      Thanks everyone, a great help and the advice looks to be sport on. One more question! How do I display four seperate gpx files on one screen as a tour? Thanks again all 🙂
                        @Gary-Hargraves
                          @Gary-Hargraves
                          Gary Hargraves
                          @Mzokk - thanks a million 🙂
                          Mzokkundefined
                          Carl Leeundefined
                          Carl Lee
                          Garry Davis
                          Gary Hargraves
                            2.8k
                            Aiello antoninoundefined
                            2.9k
                          • Doe ik iets verkeerd of...
                          • Crashes na update
                            Lluis Arasanzundefined
                          • CarPlay says that I need a subscription
                          • nav 6 route problem
