  4. Could it be this easy?
5 Posts 3 Posters 1.3k Views 4 Watching
  • Greenhamundefined Offline
    Greenham
    I'm a huge fan of MRA, and use it exclusively for my MC route planning. It make me nervous when I import into the Garmin Zumo, when it says "CALCULATING"
    I am still have an occasional problem where my Garmin Zumo XT doesn't follow the route (Recalculation is turned off)
    I noticed you MUST PICK a routing option in the Zumo (Fastest, Shortest etc) Mine is set to fastest. But everyone that has a Garmin has this issue.
    Is it as easy as just adding more shaping points?
    I normally try to minimize the shaping points and VIA points to just what I need to make MRA shape the route I want. I think that may be fine for MRA, but with Garmin set to Fastest, if you don't have enough shaping points it will calculate the fastest route by ignoring the few shaping points you do have.
    Hans van de Ven MR.MRAundefined martin-phogel.deundefined 2 Replies Last reply
    • Greenhamundefined Greenham
      @Greenham
      The Zumo will always calculate the route, differences are often because the waypoints may be too far apart, causing the Zumo to choose a different route.
      Would you mind sharing the URL of your route, so I can put your salt on my Zumo to check? Make sure the route is public.
      Greenhamundefined 1 Reply Last reply
        @Greenham
        Greenham
        @Hans-van-de-Ven-MR-MRA
        Thank you for the quick response. I would have sent a link, but I have already added a lot more points on the route suspecting that the lack of shaping points was the problem.
          martin-phogel.de
          @Greenham
          If you use a Zumo XT (not XT2) and navigate with automatic recalculation turned off, you might want to consider using the GPX 1.2 export format (either "export" it via USB to your device or use "save as" and then transfer it via Germin Drive app).
          In a nutshell, you will end up with a route on your Garmin that behaves as accurately as a track with turn-by-turn indications and still announces the via points (not shaping points).
          This was my preferred way to navigate with my Zumo XT, and that is why I love the feature "navigating routes as tracks" implemented to MRA NN with the latest update, as it behaves similarly.
          If you want to learn more about GPX 1.1 versus GPX 1.2 you will find an excellent article here:
          https://forum.myrouteapp.com/post/17233)
          • martin-phogel.deundefined martin-phogel.de
            @Greenham
            Greenham
            @Martin-Wilcke
            Thank you for the great answer. I do export as Zumo XT 1.2 and rarely have an issue. But I have now learned that have to FEW shaping points can/will cause the Zumo to look for the default selection (Fastest, Shortest, Curvy) if it doesn't have another shaping point close enough to the last.
            I'm still unclear on the value of export Route as a Track. Even after Serg's video I'm not sure what I am gaining. vs export to 1.2
            martin-phogel.de
            Greenhamundefined
            Greenham
              6.5k
              6.1k
            • MRA 5.2.1 (480) False message - since Internet is available
            • Skipping a Via point...
              Lenny Oundefined
              Lenny O
              John S Parryundefined
            • Veekeersinfo en omleiden
              marko 11 0undefined
              marko 11 0
              13.0k
