  3. Rally Navigation
Rally Navigation
4 Posts 2 Posters 1.1k Views 1 Watching
  • M J Smallshaw Offline
    M J Smallshaw
    What I need to be able to do create a route for a rally is create multiple waypoints (without automatically creating a route), then by looking at the map with the waypoints on choose which waypoints I want to use and in what order to enable me to then create a route for the rally. I can do this on Basecamp (with difficulty) but can I do it on MRA?
    Nick Carthew 2 Replies Last reply
    • M J Smallshaw M J Smallshaw
      Nick Carthew Offline
      @M-J-Smallshaw Adding waypoints will always create a route. What you could do is use POIs instead of waypoints. Use the Manage tab in the POI library and add POIs as visual representation of where the waypoints would be.
        @M-J-Smallshaw
        Something like this. The POI acts as a visual marker when you’ve worked out your route start adding waypoints.
        M J Smallshaw 1 Reply Last reply
          @M-J-Smallshaw
          M J Smallshaw
          @Nick-Carthew Thanks Nick, that makes a lot of sense, I'll start practising!
          M J Smallshaw
          M J Smallshaw
          • Welke instelling
            1.0k
            Thomas Schäfer
            Thomas Schäfer
          • opslaan naar plantomtom
            chris 18
            chris 18
          • Seizoen sluitingen wegen
            PAT62
            PAT62
          • App loopt vast
          • Rejoining routes
            Sytze van der Laan
            Sytze van der Laan
