  3. MRA Navigation Next support for Chigee AIO-5 and BMW Multi-controller
17 Posts 7 Posters 6.3k Views 4 Watching
  • versluis versluis
    @Stephen-Rowland
    'Maybe you can still cancel this
    There will be one in July that you can simply connect to the BMW system and it will work with the wonderweel
    https://www.chigee.com/nl/pages/introducing-upcoming-aio5-play-bmw-edition?_pos=1&_psq=bmw&_ss=e&_v=1.0
    Stephen Rowland
    Stephen Rowland
    Stephen Rowland
    @versluis Thanks for the information. I’ll look into that
    • cerfskysky.com
      cerfskysky.com
      cerfskysky.com
      @Dae-0
      Thanks for reply. The new chigee mentioned coming out in July could be interesting for my BMW, although I have a Carpuride 702 at the moment which I like very much. Having clicked on the link from versluis, in the advertising of their new BMW offering, it mentions the ConnectedRide Nav system. I presume this means Navigation preparation? It will be interesting to follow some YouTube tests of the device.
      versluis 1 Reply Last reply
      • cerfskysky.com cerfskysky.com
        @Dae-0
        versluis
        versluis
        versluis
        The first video of Chigee’s new system
        https://youtube.com/shorts/6b6KX4omO9A?si=QRxD8EVkRfxMGmtI
          Does anyone know if MRA Navigation Next will support the BMW Multi-controller if the bike has been equipped with the Chigee AIO-5? This device has CarPlay/Android Auto and is connected via the Canbus. It looks very clever having a touch screen.
          Ronny Schenkels 0
          Ronny Schenkels 0
          Ronny Schenkels 0
          @Carl-Flint Hi, I have the chigee aio-5 lite installed on my BMW R1250RS, including the 4-pin canbus adapter to control the Chigee with the BMW Wonder Wheel (WW).
          It works okay, also the MyRoute-app works perfect (v4.1.3).
          To be honest, I rarely use the WW because it only has a 'tab' function to scroll from one icon to another one on the selected carplay application screen, and an 'Enter' button to select the choosen icon.
          I mainly use the touchscreen and the 4 upper bottoms on the device, as the screen is very responsive.
          I hope that Chigee would further enhance this WW features, by supporting the turning of the WW (for example to zoom in or out) , or to control the Volume for example.
          But, a happy Chigee user here
          ps: I sold my brand new Zumo XT2, as I no longer wanted to 'convert routes' since the MyRoute-app has all the features I need, and also the offline possibilities are very good
          Ron
          BMW 1250 RS '23
          Garmin Zumo XT2 (sold)
          Chigee AIO-5 Lite (sold)
          Innovv N1 Pro (sold)
          Chigee AIO-6 MAX
          cerfskysky.com Ronny Schenkels 0 Ton Verkleij 3 Replies Last reply
          • Ronny Schenkels 0 Ronny Schenkels 0
            Ron
            cerfskysky.com
            cerfskysky.com
            cerfskysky.com
            @Ronny-Schenkels-0
            Hi Ronny, thanks for posting this info, very helpful. The Chigee looks a good device. I am not interested in the Dash Cams part of the package and for the moment the Carpuride is performing very well. I agree with your comments about not wanting to ‘convert routes’, no need with MRA app. I hope the next iteration of the Chigee will allow more functionality from the BMW multi-controller and maybe be sold separately from the Dash Cams. That would interest me. We will see soon I believe.
            Stephen Rowland 1 Reply Last reply
              @Ronny-Schenkels-0
              Stephen Rowland
              Stephen Rowland
              Stephen Rowland
              @Carl-Flint I have just received and fitted the “Play” version without cameras. I removed the BMW satnav prep and the CHIGEE sits lovely on the mounting bar and wires into the sat nav socket. I have also mounted my iPhone on a Quad lock bar mount. So on dry days I can get the full screen functionality of the iPhone app plus the Chigee for quick glances. If wet the iPhone goes into the R1300GS cubby hole. It picks up satellites with no problem. I don’t think I really need whizzy wheel functionality. I’m very happy with this set up
                Ron
                Ronny Schenkels 0
                Ronny Schenkels 0
                Ronny Schenkels 0
                @Ronny-Schenkels-0 in the mean time, a software updated has arrived for the Chigee AIO5-Lite, version 2.8, and now the Vertical scrolling of the BMW Wonder Wheel is supported, very nice !!
                BMW 1250 RS '23
                Chigee AIO-6 MAX
                  Ron
                  Ton Verkleij
                  Ton Verkleij
                  Ton Verkleij
                  wrote on last edited by Ton Verkleij
                  @Ronny-Schenkels-0 I have been informed by Chigee Support that a new 3 pin can-bus remote control unit will come out in September, enabling scroll navigation with the wonderwheel on the Chigee io-5 Lite.
                  This will fit on the can-bus adapter on my 1250 GS.
                  • Ton Verkleij Ton Verkleij
                    @Ton-Verkleij said in MRA Navigation Next support for Chigee AIO-5 and BMW Multi-controller:
                    what does that look like then?
                    wie sieht das denn dann wohl aus ?
                    Dae 0 1 Reply Last reply
                      Dae 0
                      Dae 0
                      Dae 0
                      @Hubert-Thoring I have one. You unplug the BMW GPS mount, and in its place plug in the CGRC-LIN adapter. It’s about 2.5cm x 5cm. It pairs with the AIO-5 Lite via Bluetooth.
                      With it you can use the Wonderwheel to move a highlight box around all the clickable CarPlay elements to select them. It’s a bit like in Windows using the tab key to move between UI elements then hitting space to select. It’s much simpler than it sounds. The connector also transmits the data such as BMW native tyre pressures, rpm, fuel level etc. to the Chigee, which has its own BMW screen.
                      This is the best way to use the wheel with the original AIO-5 lite.
                      The alternative, if you don’t already have a Chigee, is to buy the BMW version. This doesn’t need a separate controller as it sits in the BMW cradle and gets the information from the bike directly.
                        @Dae-0
                        Is there a video about the solutions and applications? I would like to see it.
                        • CGRC-LIN adapte Link zu Chigee
                        • BMW AIO-5 Link zu Wunderlich
                        I would like to see the operation of a navigation app, e.g. with MyRoute app and the zooming or skipping waypoint
                        I personally use the MyRoute app on the iPhone Xr and the Remotek One for zooming. It would be very interesting for me to see the difference between this and CarPlay.
                        This is my hardware:
                          @Dae-0
                          Dae 0
                          Dae 0
                          Dae 0
                          wrote on last edited by Dae 0
                          @Hubert-Thoring
                          I’m not sure about videos showing the MRA functionality. There must be some out there given how many people have them.
                          Remember that it’s a touch screen device. You can operate all of CarPlay with the wheel, as I do with non touch gloves, but you can equally operate it by touch only (or a mix of the two)
                          There are 3 versions, but only two are really relevant.
                          The original AIO-5 Lite. This has two cameras that act as dashcams. It’s a fixed (bolted) and doesn’t use the BMW cradle. You combine this with the CGRC-Lin to get Wonder wheel functionality and bike data onto the device. This is what I have.
                          Then there’s the Play BMW edition. It fits in the BMW cradle and doesn’t need the CGRC-LIN. There no cameras with this version as obviously the BMW GPS cradle has no wiring for cameras.
                          Except for the cameras and the different mounting, both versions offer the same functionality, screen size and work exactly the same.
                          This video may help if you watch from 20:00 onwards.
                          One thing that is a pain is the fact you can’t alter the zoom level in MRA from the CarPlay screen. This is an MRA issue. I use Scenic and it has zoom in/out buttons on the CarPlay screen that I can select with the Wonder wheel or by touch.
                          Skipping a waypoint is easy. Rotate the wheel until the skip button is highlighted, then nudge the wheel to the right to select it. Or, just tap it on the screen if you don’t want to use the wheel.
                          https://youtu.be/x5vHkpZkYOk?si=_W67gjaF4Ilu3nJB
                          • Dae 0 Dae 0
                            @Hubert-Thoring
                            @Dae-0
                            Thank you for this extensive information. VG 👋
                            Dankeschön für diese umfangreiche Information. VG 👋
                            Dae 0
                            Dae 0
                            Stephen Rowland
                            Stephen Rowland
                            Ronny Schenkels 0
                            Ronny Schenkels 0
                            versluis
                            versluis
                            Ton Verkleij
                            Ton Verkleij
                            cerfskysky.com
                            cerfskysky.com
                              TomOnTour
                              TomOnTour
                            • Android Auto TFT
                            • Select friends problem
                              stuart marritt
                              stuart marritt
                            • Volgorde van dagen omgedraaid in Collectie vs Tour
