  4. No skip waypoint in offline mode
10 Posts 5 Posters 94 Views 4 Watching
  • Jörgen Offline
    Jörgen Offline
    Hi, I was sometimes offline because of bad GSM signal. During the offline time, I could not skip waypoints.
    Is this normal?
    Hubert Thoring Con Hennekens Rob Verhoeff 3 Replies Last reply
      Is this normal?
      Hubert Thoring Offline
      @Jörgen
      Hello Jürgen,
      Then switch to offline navigation then it works. That's why I'm on offline.
      VG
      Hallo Jürgen,
      dann umstellen auf Offline Navigation dann geht es. Das ist der Grund warum ich es fest auf offline stehen habe.
      VG
      iPad 9. Gen iOS 26.6/ iPhone 16e iOS 26.6/ Navi iPhone Xr iOS 18.7.10 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
        Is this normal?
        @Jörgen, If you have offline maps, that should not be a problem. It can just take some time for the app to conclude that there is no online signal.
        • Jörgen Offline
          Jörgen Offline
          @Con-Hennekens I tried 4 times and did not work, then about 10 min. later it jumped to the 4 later WP. Realy starnge behavier.
          Dave J 0 Con Hennekens 2 Replies Last reply
            Dave J 0 Offline
            Dave J 0 Offline
            @Jörgen Same has happened to me too. You are not alone.
            Ducati Multistrada V4 Rally
            iPhone 15 Pro
            CHIGEE AIO-6 LTE
              Is this normal?
              Rob Verhoeff Offline
              @Jörgen Just tried it out. It works for me as expected. Offline, I can skip waypoints without any issues. It doesn't matter whether I disconnect from the internet during the route or start the route entirely offline.
              Hubert Thoring Con Hennekens 2 Replies Last reply
                @Jörgen @Dave-J-0 @Con-Hennekens
                Yes Offline is the solution, and makes a lot easier on the go. Assumes that you have prepared the cards and settings correctly.
                So it always goes very well !!
                  @Rob-Verhoeff, I suspect Jörgen means online, but with bad internet signal. Then it can take a while before the online calculation is done.
                  @Corjan-Meijerink, some time ago there were ideas about a better way of measuring the internet status. Is this still on the wishlist? Or has anything been implemented already?
                  Jörgen 1 Reply Last reply
                    @Jörgen said in No skip waypoint in offline mode:
                    To which WP it will jump is largely dependable on which WP is closest at the time if the calculation. I think if you have been running with quirky recalculations for ten minutes, you might have passed multiple route suggestions while it was calculating. That will indeed make it very confusing where it will jump to.
                    I suspect the round arrows were circulating in the upper left of the screen? (on the phone screen, don't know about how carplay shows this).
                      Jörgen Offline
                      Jörgen Offline
                      @Con-Hennekens said in No skip waypoint in offline mode:
                      Correct.
                      Offline maps are available, and Internet connection was bad. At this point I needed to skip WP and it was not possible.
                      I tried some time but nothing happened, so I drove the skip area just with a zoomed out map. Later, the skipped WP was done automatically.
                      • Duur van de route klopt niet
                      • Gidday from New Zealand.
                      • Beeld loopt achter
                        Maarten van de Wijdeven
                        Steve Jarrell
                        Steve Jarrell
                        27.9k
                      • Traject controle
