  3. Next update for the BMW Connected Ride Navigator
21 Posts 10 Posters 9.8k Views 5 Watching
    @Hubert-Thoring No definitely not.
    In the general discussion, questions like these are absolutely fine.
    @Dirk-007 Thanks for asking 🙂
    And indeed, please try to respond in the original language as started by OP
    @Corjan-Meijerink : Sorry !!
      @Jörgen
      Sorry 😢
      @Hans-van-de-Ven-MR-MRA No problem Hans, just a friendly reminder.
        @Jörgen 😉
        • Dirk 007
          Dirk 007
          Dirk 007
          wrote on last edited by Dirk 007
          And in the meantime I am installing version 20240819-V1.0.4. Then looking for the new functionalities and improvements. I had already read that the CRN can now also import waypoints in stead of only anchor points. I am curious....
          • Tony 13
            Tony 13
            Tony 13
            I have been importing waypoints on CRN for 2 months using GPX1.1, had never tried it before. Initially input shows straight lines between waypoints, but when you start navigation it works out a proper route
            Note I am getting very risk adverse in my old age. Now I take a Tom Tom, MRA and CRN on trips in case something goes wrong. Although with only 1 mobile phone there is a common risk factor to 2 of those☺
            Dirk 007 1 Reply Last reply
            • Tony 13 Tony 13
              Dirk 007
              Dirk 007
              Dirk 007
              @Tony-13 Do you have space enough to store your other stuff? 😄
              I export my MRA-route now as a 1.1 gpx, but new to this release is that you can choose during import in the CRN wether you want to import the route with anchor points (steunpunten) not visible as you stated and/or with waypoints (routepunten) visible incl. audio warning and/or tracks. In the precious version, I had to import the routes in the BMW-app en convert it to a route with waypoints. Now al can be done in the CRN.
              I also noticed that the CRN calculates the route much faster, especially if the route is several hunderds km away from where you are. I opened a ticket for this issue a few months ago which apparently has been solved.
              let's see next week when a go for a 8 day trip to the Jura in France.
              BTW: my buddy has a tomtom so I can spare some space 😆
                @Corjan-Meijerink I use Google translate on Chrome. I don't even see the original language. If I can't reply in English then I guess I'll get no value from posts in other languages.
                Con Hennekens Stefan Hummelink 2 Replies Last reply
                  @RetiredWingMan, "TRY" being the keyword here 😉 I gave up on Translate some time ago. Too many details get lost in translation. Deepl does a much better job (imho) and is context sensitive too.
                    @RetiredWingMan said in Next update for the BMW Connected Ride Navigator:
                    Well, imho English is sort of special. The 'same language' thing is mainly intended to prevent users answering i.e. Dutch on a thread started in German.
                    In any case, answering in English while also putting out a translated version of your text, would be much appreciated in threads started in languages other than English.
                    • Patrick 37
                      Patrick 37
                      Patrick 37
                      I just installed the new update and want to test it, but I can't get my CRN connected to my MacBook Pro. I saw in a presentation of Hans that he did manage to get this work. for the update I imported routes from the mra app to the connected app and convert it in waypoint.
                      but now I want to try it the new easy way with the crn connected with the pc.. I tried different ports and cables. even the original one.
                      does someone have this same problem? or do I need to install a program for this?
                      hope someone can help
                      Dirk 007 Tony 13 2 Replies Last reply
                      • Patrick 37 Patrick 37
                        Dirk 007
                        Dirk 007
                        Dirk 007
                        @Patrick-37 This problem is also known for Garmins with MacBook (unregarding the OS installed). Apparently you'll need an adapter type "usb c digital av multiport". Still quite expensive
                          Tony 13
                          Tony 13
                          Tony 13
                          @Patrick-37 said in Next update for the BMW Connected Ride Navigator:
                          I save my my routes to a Microsoft or Google cloud drive, and can pick them up in CRN from there. Being an Android user the Google drive works best
                          • Patrick 37
                            Patrick 37
                            Patrick 37
                            @Dirk-007 I don't know what I can do more with a device like that, my MacBook Pro isn't really new. so I have an usb A port on it. with the usb A to usb C cable that was included in the CRN box I tried It and I tried it with almost every other usb a to c cable haha
                            @Tony-13
                            Yeah, i do it the same way for now only with the iPhone myroutes app and the connected ride app from bwm. this will sync due my bmw id to my crn.
                            its a bit complicated as you see, that why I hoped I can connect it to my laptop but unfortunately that doesn't work
                            Tony 13
                            Tony 13
                            Dirk 007
                            Dirk 007
                            Patrick 37
                            Patrick 37
                            • Frozen marker.
                            • Recent trip made hard !
                              Kirsten De Weerd
                              Kirsten De Weerd
                            • Kan keuze voor voertuigbeperking worden ' onthouden' ?
                            • Blauwe lijn en witte lijn in de navigatie ?
                              2.4k
