  4. Time/speed calculations
10 Posts 5 Posters 1.6k Views 3 Watching
  • Klaus rundefined Offline
    Klaus r
    wrote on last edited by Klaus r
    When planning I discovered now that the travel time calculated between 2 route points are shorter then they were in previous versions.
    That ends up in too high averages for speed.
    E.g. >60 to 80 km/h - for profile Car with the option Avoid Highways!
    Error in the one of the last updates?
    Klaus rundefined Hubert Thoringundefined 2 Replies Last reply
    • Klaus rundefined Klaus r
      Klaus r
      No reply, no reaction from MRA?
      I have made some test with kurviger. The times it calculates are much better.
      There is something wrong in the routeplaner (web).Be it in the calculation or in the map data.
      Which speed values do you use for the different type of roads?
      Over all, I like the routeplanner very much but ... I am rather disappointed now. Instead of implementing more features you should take care to get the basics more usable.
      In addition I propose to implement a simple speed correction factor to be applied to all type of roads.
      So one can adjust the time calculations to its own needs.
      Fast, slow, group rides etc.
        @Klaus-r As far as I know there haven't been any changes in the average speed tables. I do know that MRA will always keep on the very safe side of speedlimits. So what you experience must be something else. Maybe you can share such a route with us and make shure it's set to public so we can have a glance
        Klaus rundefined 1 Reply Last reply
          Klaus r
          @Marinus-van-Deudekom
          Ok, will do it on Friday.
          But I do not believe that it will depend on a route. I experienced it with several routes.
          • TomOnTourundefined Offline
            TomOnTour
            Hello @Klaus-r,
            as I was using MRA in parallell with my Garmin XT2 and experienced that the difference between MRA and the Garmin device even on routes with more than 300km is in a range of 5-10 Minutes. This difference is coming von minor differences within the final routes.
            My understanding is, that MRA and Garmin are using the same routing algorithm. Seeing this minor differences between MRA and Garmin this seams to be correct.
            I know that Garmin had something like the individual speed definitions for specific road types, but this is no longer available.
            Personally I don‘t see really relevant differences between the planned times and my reality on my routes. I don‘t think, that a difference of a couple of minutes in a tour is no problem for me.
            Greetings
            Thomas
            MyRoute-APP Navigation Next (V5.0.4 - 451) on MDT665 Navigation phone
            using iPad Pro (iPadOS 26.4.1) and Macbook Air (macOS 26.4)
              @Klaus-r : In the application with the motorcycle, I am often surprised how well the time fits when we have arrived at the stopping point.
              I have no objections, it's an orientation.
              VG 👋
              iPad 9. Gen iOS 26.4.2/ iPhone 16e iOS 26.4.2/ Navi iPhone Xr iOS 18.7.8 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
                @Klaus-r, those duration calculations are inherent to the the HERE algorithms. Traffic can have an impact as well as closed roads that reopen or vice versa. You could try if these differences still occur if you disable seasonal closures in the toolkit. That way traffic and closed roads are not considered during planning.
                @Klaus-r said in Time/speed calculations:
                The basics are really great as they are. I think it is a bit short-sighted to claim this.
                  Klaus r
                  Strange.
                  When riding with a group we were always too late. More than just some minutes.
                  Why???
                  If there are really no longer individual speed definitions for specific road types available that would explain bigger differences.
                    Strange.
                    Why???
                    Klaus r
                    As asked for a route example. Simple A-B, no shaping or via points, no breaks.
                    Options set:
                    Avoid highways
                    Avoid unpaved roads
                    Disable seasonal closures
                    Fastest road
                    Map = HERE
                    Results
                    Motorcycle 236,02km, 3h 10m
                    Average speed = 236,02km / 3,166h = 74,53 km/h
                    Car 233,94km, 3h 26m
                    Average speed = 233,94km / 3,433h = 68,14 km/h
                    Motorhome same as car! (lenght 650cm, weight 3490kg)
                    https://www.myrouteapp.com/en/social/route/9783965?mode=share
                    So, why are the average speeds so high?
                      Options set:
                      Avoid highways
                      Avoid unpaved roads
                      Fastest road
                      Map = HERE
                      Results
                      @Klaus-r I still don”t know wat these rifferences apear in the web planner. I”Ve looked at the route in the next app and heen I change the transport mode the distance AND thé total time stay the same
                      Marybelle @Corjan-Meijerink can explain wat. And oerhaps hé can and will let us know What aversge sledes are beding used in Beth thé planning and next version.
                      TomOnTourundefined
                      TomOnTour
                      Klaus rundefined
                      Klaus r
                      • Joining a planned route from a differant position.
                        Jose antonio marin seguraundefined
                        411
                      • Rijrichting in route
                        1.4k
                      • Problemen route opslaan naar plan.tomtom
                      • running myRoute-app on a carpuride
                      • What exactly am I looking at?
                      • Exporting route from app to Garmin XT webpage not available
                      • MRA basic
                        b0hd1undefined
                      • Track prefix name when exporting through web or andorid MyRouteApp
                        Will Brooksundefined
                        Will Brooks
