  4. Editing Route Question
3 Posts 2 Posters 664 Views 1 Watching
  • Jeff Molldrem
    Jeff Molldrem
    Jeff Molldrem
    New to the Forum so I apologize in advance if I breach any forum etiquette. I am currently creating an overly ambitious multi day motorcycle trip in the US. With the hopes of someday actually doing it. I have a couple questions before I continue editing the route.
    Is there any way to reset the total time clock so that each day the time starts over from a specific start time?
    Can I put in multiple Start points?
    I just found a post about the Zumo XT and waypoint limitations. Now that I have the whole route plotted from start to finish this could be an issue. Is there any easy way to copy the route for each day into a separate map to lower the waypoint count? Or will I have to redo everything? I like seeing it on one map but realize it might be a bit much to export to my navigation system. Thanks in advance.
    • Jeff Molldrem Jeff Molldrem
      @Jeff-Molldrem, yes, I would advise you to snip the route into daily sections. Use the "split" function in the toolkit. You can then select the waypoints at your accommodations. New routes will be generated, and each end point becomes the start point of the next route. You need a Gold subscription for this though.
      Jeff Molldrem 1 Reply Last reply
        Jeff Molldrem
        Jeff Molldrem
        Jeff Molldrem
        @Con-Hennekens Thank you for that very easy solution.
        Jeff Molldrem
        Jeff Molldrem
          4.2k
        • Points of interest
          LluĂ­s Casals
          LluĂ­s Casals
          4.2k
        • Altitude numbers size
