  4. Sharing route via email?
4 Posts 2 Posters 1.3k Views 1 Watching
  • Lenny Oundefined Offline
    Lenny O
    I am in my route.
    It is on the map.
    It is Public.
    I click Share > Email and nothing happens....
    I would expect some kind of email program to open.
    Am I missing something in a setup?
    Thanks!
    • Avery Jonesundefined Offline
      Avery Jones
      Check if you have an email client set up and as the default for handling email links. You might need to restart your device or reinstall the mapping app if the issue persists.
      Lenny Oundefined 1 Reply Last reply
      • Avery Jonesundefined Avery Jones
        Lenny O
        wrote on last edited by Lenny O
        @Avery-Jones Is that a setting inside the MRA?
        Otherwise my email opens on links.
        Thanks!
          Avery Jones
          The problem could be in your device's email setup, not inside the MyRoute app. Check that you have correctly set up your favorite email client. It is configured as the main application for managing email links. You can usually adjust this setting in your device settings, under "Default apps" on Android or within the "Mail" settings on iOS. If your email app is set as default already, but you still have trouble, try to reinstall My Route app will help with the problem.
          Lenny Oundefined
          Lenny O
          Avery Jones
            Massimo Cardoneundefined
            Massimo Cardone
            -3
          • Veerpont als routeovertreding gaat te ver
            Leike Lodiersundefined
          • Waypoints and POIs disappear while moving/zooming the map in web planner
            Tom Balmerundefined
            Tom Balmer
          • Fout in route bibliotheek
          • Search for routes containing a 'favorite' waypoint
          • Testrit met AA ivm tracklog
            supergundefined
          • Track log functionality - compared with BaseCamp
            John Matthews 0undefined
            John Matthews 0
