  4. Waypoints not exporting (using different nav apps)
16 Posts 6 Posters 5.3k Views 1 Watching
  • andrea 3m andrea 3m
    Hi guys! Andrea from Italy
    So I’m pretty sure I’m doing something wrong since I’m learning everything from zero, so excuse me if I’ll say something that does not make any sense.
    I’m planning a ROUTE on the route planner and I want to export the gpx file on a different app like Osmand or DMD2 but whatever format I save the track in (1.1 1.2 etc) won’t show any of the waypoints I had planned on the route, is that normal or am I doing something wrong? I think I’ve understood that those kind of apps will only follow tracks and won’t use route, so maybe I’m doing something wrong in the planning?
    @andrea-3m
    Hi Andrea OSMand will show a navigational track. Waypoints will be missing. If you create a route in OSMand then the waypoints will show.
    andrea 3m 1 Reply Last reply
    • Mzokk Mzokk
      @andrea-3m
      andrea 3m
      andrea 3m
      andrea 3m
      wrote on last edited by andrea 3m
      @Mzokk but when I import a track from anywhere else that have waypoints, the track once on Osmand, it has the same waypoints that it had on the original file.
      For example if I plan a route on base camp or download a track from wikiloc, I do have all my waypoints showed on the Osmand map, is there no way to export them from Mra if you are not using a garmin device ?
      Guzt 1 Reply Last reply
        Guzt
        Guzt
        Guzt
        @andrea-3m A track, where ever it comes from, has only 2 waypoints: start and finish. Thats it.
        Only routes can contain waypoints. You need to use gpx 1.1 (route, track, POI) in order to see your waypoints in the route.
        • Robert Smith 2
          Robert Smith 2
          Robert Smith 2
          I have just posted a similar topic. I am trying to export a route from MRA to the Beeline Moto app. No matter what format I save and export as, all I get is the track. I have tried gpx 1.0, 1.1 and 1.2 with the same results.
          • Robert Smith 2 Robert Smith 2
            Guzt
            Guzt
            Guzt
            @Robert-Smith-2 does beeline support routes with waypoints in it or only tracks?
            Robert Smith 2 1 Reply Last reply
            • Guzt Guzt
              Robert Smith 2
              Robert Smith 2
              Robert Smith 2
              @Guzt Apparently it does. There are plenty of screen shots of imported routes with waypoints showing. i have also raised a case with beeline to ensure i am not expecting something that doesn’t actually work
                Guzt
                Guzt
                Guzt
                @Robert-Smith-2 it looks like beeline only recognizes the track in the gpx file which contains and the route including your waypoints and the track.
                • Guzt Guzt
                  Robert Smith 2
                  Robert Smith 2
                  Robert Smith 2
                  @Guzt Beeline support have been in touch and they have asked for my gpx file, which I have sent. They certainly claim to be able to import tracks and waypoints and show screen shots of such files. But I have exhausted all options of trying to upload various files, including calimoto, google maps etc. So will see what they come back with - thanks for you help
                  Guzt Lynchy67 2 Replies Last reply
                    Guzt
                    Guzt
                    Guzt
                    wrote on last edited by Guzt
                    @Robert-Smith-2 Make a test route on kurviger e.g. [link text]https://kurv.gr/8J7xg(link url) (I just imported a gpx route made in basecamp) and export it as a route, including waypoints and import that into beeline. Just wondering about the result? Perhaps this solves your problem.
                    • Guzt Guzt
                      Robert Smith 2
                      Robert Smith 2
                      Robert Smith 2
                      @Guzt I don't use basecamp, that is why I moved to MRA, so haven't tried that.
                      • Bouke Ent
                        select export gpx 1.1 route and track. if you import it in osmand it will import both. in route you will see your waypoint, track is shown in background if you have that option on. be aware that osmand wil calculated route based on setting and given waypoint. it can be differant as in MRA.
                          Guzt
                          Guzt
                          Guzt
                          @Robert-Smith-2 @Robert-Smith-2 didn't knew my English was that bad. If you don't have a free account on Kurviger, make one first. Log in and then click on the link given above. Save that route as route + waypoints and import it into beeline in order to see what happens.
                          • Guzt Guzt
                            Robert Smith 2
                            Robert Smith 2
                            Robert Smith 2
                            @Guzt Sorry, misunderstood. Your English is excellent. I will try tomorrow. Thanks
                              @Robert-Smith-2
                              Regarding the Beeline Moto, I believe you can import routes but the output is always a Track.
                              • Lynchy67 Lynchy67
                                @Robert-Smith-2
                                Robert Smith 2
                                Robert Smith 2
                                Robert Smith 2
                                @Lynchy67 I have come to the same conclusion, although they advertise you can import a route with waypoints and the support guy who I have sent the gpx too, seemed surprised it didn't work and only imported a track. This is not a big issue for me, track is ok.
                                Guzt
                                Guzt
                                Robert Smith 2
                                Robert Smith 2
                                andrea 3m
                                andrea 3m
                                  MartinW
                                  MartinW
                                  MartinW
                                  MartinW
                                  Rory Burke
                                  Rory Burke
                                • Béta to no-béta
