  3. Finish line, hand with question mark…?
6 Posts 4 Posters 1.2k Views 3 Watching
  • Deividas Žalga
    Deividas Žalga
    Deividas Žalga
    wrote on last edited by Deividas Žalga
    hello, what is this? circled in red. blue hand with question mark, finish line? or question mark ? What does this mean ?alt text
    https://ibb.co/Dpm8mKr
    TomOnTour 1 Reply Last reply
    • Erdna
      Erdna
      Erdna
      @Deividas-Žalga Hi Deividas, the blue hand is the next Via Point. Can you show another picture from your planning software with not the start, but that Via Point or share the route?
      Greetings from Austria,
      André
      Deividas Žalga 1 Reply Last reply
      • Erdna Erdna
        André
        Deividas Žalga
        Deividas Žalga
        Deividas Žalga
        @Erdna https://i.postimg.cc/zDRYNJ88/IMG-9544.png
        nothing changes. hand or finish line, shows the same. a route is a single task
        Erdna 1 Reply Last reply
        • Deividas Žalga Deividas Žalga
          Erdna
          Erdna
          Erdna
          @Deividas-Žalga Ok, but now it shows a finish flag... so something has changed.
            Tapping the ETA box will toggle between:
            • Finish
            • Next shapingpoint
            • Next viapoint
            When no next waypoint of that type can be found it will display a "?" and fallback to showing the finish time.
            TL;DR tap the box to toggle back to finish flag when desired.
              TomOnTour
              TomOnTour
              TomOnTour
              @Deividas-Žalga This is happening if your next Point is nor a shaping point, nor a via point, but the finish of the route. I had the same thing today, when I replanned my route here in Norway to a direct point to point route, because of the really bad weather. If you switch in the APP to the „drop“ sign, for shaping points, you will see the same information, but with the shaping point drop with a question mark in it.
              Ultimately nothing to worry about.
              Greetings
              Thomas
              TomOnTour
              TomOnTour
              Erdna
              Erdna
              Deividas Žalga
              Deividas Žalga
                506
              • Statement on map spinning
                1.8k
                Barto
                Barto
              • MRA Route planner Next
                peha
                peha
