  4. Creating POI lists with MRA
17 Posts 9 Posters 3.9k Views
  • martin-phogel.deundefined martin-phogel.de
    @Don-Stauffer
    My understanding so far:
    1. POI collections in <Search> are available for all users in all new (and existing) routes.
    2. POIs in <Library> are also available in all routes, but only for the user who added the collection with upload.
    3. POIs in <Manage>, on the other hand, are bound to exactly this route.
    So when you create a new route, you can access the POIs in 1. and 2. but not in 3. (from other routes)
    Therefore my idea: I create a route as a template for a trip and add all POIs there that I want to visit and that are not included in 1. or 2. When I then plan individual routes, I do not create new routes but always copy the template.
    The way you described should work and the POIs in <Library> should be visible. Maybe you have to zoom in a bit more.
    Jack van Tilburg
    @Martin-W
    In general you are right.
    Additional information can be found in this support article.
    Manual POI's
    I don't think my description to make your own POI list is included
      When I plan a motorbike trip, I first make a list of POIs that I (probably) want to visit.
      In the second step, I plan individual routes in which I add the corresponding POIs as Viapoints. In the process, of course, I sometimes discover more POIs that I want to add to my list.
      However, I cannot create a POI list within MRA Route Planner.
      The only way I can think of is to plan a dummy route in which I collect the various POIs together. If a certain point is already included in an existing POI collection (either the lists included in MRA or one of my own uploaded list), I can add it as a POI to the route. I can then split or copy the dummy route into individual routes to plan my day trips.
      If I want to add POIs that are not already in a collection, I have to create favourites instead - which I don't want to do because I use favourites for a different purpose.
      All in all, it's not really a smooth way.
      Alternatively, I could create my POI list with another app and then load it into MRA. That works fine - but of course I would like to do everything with MRA πŸ™‚
      Any ideas for a better workflow?
      Drabslabundefined Offline
      wrote on last edited by Drabslab
      @Martin-W
      I think that the whole POI/Favorites aspect in the routeplanner could use a serious update. And now that we have Next, the limitations of other GPS devices are less important.
      In myview, POI and Favorites are largely the same.
      Maybe I write a "suggestion" on this topic
      martin-phogel.deundefined 1 Reply Last reply
      • Drabslabundefined Drabslab
        @Martin-W
        martin-phogel.de
        @Drabslab said in Creating POI lists with MRA:
        This can lead to long and endless discussions πŸ™‚
        But I agree. If I had a way to manage "my own POIs" well, I would not need "favorites".
        After all, the topic is already on the MRA Routeplanner roadmap. I am a new user, so my question is: Is there typically information available in advance about a planned new or changed feature, so that users can contribute their ideas?
          Jack van Tilburg
          @Martin-W said in Creating POI lists with MRA:
          You can take a look at the The road to MRA Routeplanner point 1.9
            @Martin-W
            You can create your own POI list. It is laborious.
            Open a new route - go to <Points of interest> in the left column and choose the middle tab <Manage> - Click "Add" and place your POI, name it. Repeat with all the POIs you want to create.
            Then go to the menu at the top of the screen and choose <Save as>. There you will find the option for POI.
            Then go to <Routlab> and choose <Upload> and in the next window "POI". Follow the clue.
            Your POI list is now listed under the "Library" tab
            Nigel Ralphsonundefined Offline
            Nigel Ralphson
            @Jack-van-Tilburg said in Creating POI lists with MRA:
            Hi, this may sound stupid but I cant find <Points of interest> in the left column. In fact, I cant see a left column on my screen.
            • Nigel Ralphsonundefined Nigel Ralphson
              @Nigel-Ralphson, click this arrow:
              Nigel Ralphsonundefined 1 Reply Last reply
                Nigel Ralphson
                @Con-Hennekens Aaahhhh thank you!! Told you I was stupid!! πŸ™„
                  Nick Carthewundefined Online
                  @Nigel-Ralphson said in Creating POI lists with MRA:
                  No, you’re not stupid, a stupid person wouldn’t ask for help πŸ˜‰
                    @Nick-Carthew said in Creating POI lists with MRA:
                    Exactly!
                    @Nigel-Ralphson, I wish all questions were this easy to answer πŸ˜‰
                      Ruud den Blankenundefined Offline
                      Ruud den Blanken
                      @Martin-Wilcke I browsed the forum to see if others already suggested enabling a more natural way in MRA for planning multiday trips. You suggestion comes close to my wish:
                      I create a new folder and would like it to contain the POI's and routes for a series of days. I first want to enter all overnight stays as POI's, so I can use them as endpoint for a day trip and use it again as a starting point the next day.
                      A workaround is to define all trip POI's as Favourites but this means various multiday trips share alle POI's, unless you remove them from the list again afterwards.
                      I read here that new POI functionality is coming. My suggestion is enable POI's for a series of routes to be put in a folder just like the routes itself.
                      Don Staufferundefined
                      Don Stauffer
                      martin-phogel.de
                      Jack van Tilburg
                      Nigel Ralphson
                      Drabslabundefined
                      Ruud den Blanken
                        Ewout Dundefined
                        Ewout D
                      • Am I using it wrong?
                      • Spoken streetnames
                        Herman Veldhuizenundefined
                      • Is It Me?
                        Papasmurf2undefined
                        Papasmurf2
                        1.3k
