  4. 4.1.3 - Not working offline
25 Posts 4 Posters 202 Views 2 Watching
    @ATLast
    When i try it on my phone. I see a different with your screenshots.
    My endpoint is placed on the road. Yours is not. Could this have something to do the problem.
    If i translate the French error message. I says something like it cannot the reach the destination
    ATLast
    ATLast
    ATLast
    @M-Schrijver said in 4.1.3 - Not working offline:
    The endpoint is set by the program: I simply enter the address.
      @ATLast. I have to agree with Con Hennekens that you must be missing an area map. I tried playing with various options. Note, if I have no internet then the curvy options are not available. I have offline navigation turned on.
      Internet connection NOT available: if I don't have downloaded maps I can't even get this far.
      Internet connection available:
      ATLast
      ATLast
      ATLast
      @RetiredWingMan said in 4.1.3 - Not working offline:
      But that doesn't match the situation I was in: if you look at the screenshots I posted when I was facing the problem, you'll see there was a 5G connexion.
      I don't rule out a "special" behaviour of the French roaming operator but, as I said, I conducted a few tests on my own to check if the Internet was available or not: the New York Times refreshed its page and mails and Whatsapp were ok.
      • ATLast ATLast
        @ATLast
        I did also and mine is put in middle of the road. I enter the address i could read from your screenshots
        ATLast 1 Reply Last reply
          @ATLast
          ATLast
          ATLast
          ATLast
          I use a Google Pixel 8 Pro on Android 14, are you on Android ?
          It is strange that you cannot get the same result as me.
            Yes Pixel 6 Pro and Android 14
            ATLast
            ATLast
              Michael 2v
              Michael 2v
            • Hide warnings on the map
            • Map Layers
              Martin White
              Martin White
            • Bollard trouble
