Roundabout Voice Instructions
Decided to remove UK offline maps and reload.
Removed route from download folder and removed route from my saved routes.
Re created route in My route app planner on Here maps.
Downloaded route to download folder again.
Loaded route from download folder in my route app navigation for off line navigation, checked off line navigation was selected in my settings.
Attempted to ride the route and again all roundabouts had exit 1 in the icon and voice prompts were all 'Take exit 1 at the roundabout' irrespective of the route line.
I again changed the route to on line navigation and hey presto the correct exit number was displayed in roundabout exits and the correct voice instruction.
I hope the developers can take a look at this after the weekend as it has got me beat and it is also a worrying concern as I plan to ride offline in France next month.@Mike-Whitwam Are you using Motorcycle as your transport mode? Try using Car.
@Nick-Carthew
Hello Nick, yes I have just looked and my transport mode is set to motorcycle.
The route in the planner is also set to motorcycle.
I will reset my mode of transport in the app to car and give it another try out, maybe later this evening.
Can I leave the route type in the planner as motorcycle or do you advise changing that too. -
@Nick-Carthew
Can I leave the route type in the planner as motorcycle or do you advise changing that too.@Mike-Whitwam I always use car as the transport mode. It makes no difference for us in the UK so I would suggest using car in the planner too.
@Nick-Carthew A massive thank you Nick, I reproduced the route and made my Transport mode Car and repeated part of the route including two roundabouts and every thing is sorted the roundabout Icon in the app is showing correct exit number and the voice controls are also correct.
I will as you make my transport mode 'CAR' from now on. Thankyou again Nick -
@Nick-Carthew So much for Here's promise to fix this issue!
@Rob-Verhoeff Iโm sure that Corjan will be on their backs when he returns from his well earned break.
@Nick-Carthew No doubt he'll do just that
Have you all survived the Highlands? -
Have you all survived the Highlands?Yes, thank you @Rob-Verhoeff. Lots of great memories made
The same problem with roundabouts. Each roundabout is shown as the first exit on the icon, and the voice instruction also refers to the first one. I constantly use offline mode because, in the past, when losing the GSM signal, automatic switching between online and offline modes never ended well. Additionally, I often drive in areas that are poorly covered or are in roaming zones.
@Mario-Ivancic Change the mode from 'Motorcycle' to 'Car' - as per Nick's instructions.
As ever, whan it's a 'royal pain in the a***' bug it's HERE, not MRA.
@richtea999 said in Roundabout Voice Instructions:
but
as well...
With your input, this post could be even better ๐
