  2. MRA Café
  3. Which app can I use...
4 Posts 4 Posters 1.5k Views 4 Watching
    Which App can I use just to follow a gpx Track?
    I was a rider for a photographer at a cycle race. I got the GPX track of the route, but couldn't use MRA for it. Firstly because MRA uses the road closures via the traffic information and secondly because MRA (of course) does not drive in one-way streets or on a dual carriageway in the wrong direction.
    So I need an app with which I can simply follow the track, no matter how and where it goes.
    What could I use for this?
    A question that has nothing to do with MRA for now.
      @Jörgen said in Which app can I use...:
      Well do you need any voice instructions? If you don't you surely can use MRA!
      Just "open" the track in the app and click the "compass arrow" in the bottom right. This way you activate the follow the line method in 3d and you can simply drive and "follow" the track as it shows on the screen! Try it for yourself by opening one of your own Tracklogs and see how that works. It'll work the same with an imported route-track! The map will follow your position and therefore you can follow the opened track...
      See below as an example:
      Jörgen 1 Reply Last reply
        @Stefan-Hummelink Sounds good, I will try it next time.
        No6671 1 Reply Last reply
          No6671
          No6671
          No6671
          @Jörgen
          In case the mentioned doesn't work like expected, you could give "Organic Maps" a try. It's based on OSM, like the more and better known OsmAnd+ and those maps, we do have here, but it's free. And free of tracking and fingerprinting.
          Goran
          Get up. Travel. Make friends. Sleep. Repeat.
          No6671
          No6671
          • Lock route editing
          • Group ride
          • Laat bijbehorende POI zien
            Albert van den Elsen
          • Save locations/positions
          • How do you navigate off-road routes with Next?
          • Versie 6 van Navigation Next app
          • Vreemde RPs
