  4. In the Route Planner - how can I see a Route as a track?
9 Posts 4 Posters 2.1k Views 2 Watching
  • LennyO Offline
    LennyO Offline
    In other words just not see the waypoints.
    Thanks!
    • LennyO LennyO
      Thanks!
      RetiredWingMan Offline
      @Lenny-O this was explained in another post recently. On the web page, open a new route, on the left side menu, select Route, scroll down and select the route you want and the colour and show the route. This can't be saved. Possible future option for the web site.
      LennyO 1 Reply Last reply
        LennyO Offline
        LennyO Offline
        @RetiredWingMan Thank you, but that's not quite what I want.
        You are talkin about adding a route to the same screen with the Route in view.
        I would like to see the same Route I am viewing as a track (just not see the waypoints).
        Are we on the same page or I am missing something?
        RetiredWingMan Stefan Hummelink 2 Replies Last reply
        • LennyO LennyO
          @Lenny-O that is not possible. As I said, possible future enhancement to the web site planner.
          • LennyO Offline
            LennyO Offline
            @RetiredWingMan Thank you!
            • LennyO LennyO
              Stefan Hummelink Offline
              @Lenny-O said in In the Route Planner - how can I see a Route as a track?:
              @RetiredWingMan is completely right as there are only workarounds for this at the moment. But just a clarification here:
              If you show the route as @RetiredWingMan said by adding it to an empty route, it is not added "as a route" but instead as a track! That does exactly what you like to do, however it cannot be done "in your own open route" so to say.You always need a new empty route to show it in.
              You may also try this one: save your route as a gpx 1.1 track only and upload it back into your account. Using the same method you can add the track into the route you just saved. This is the only option which enables you to show your route as a track in the same active screen since you add "a different entity" into your route, which is not the case when adding your route to your route.... Hmm sounds confusing, but you get it haha!
              Hope that helps... We'll have to be patient for the Devs to pick up the routeplanner re-design which promises a lot of nice features, even more than we already have now. 🙂
              Edit: I just thought of another workaround, instead of saving your route as a gpx track file, just simply copy your existing route in your account. Since it is not possible to add your route to itself, adding the copy is possible! Why did I never think of this before.
              Doing so shows your route and "track" of the copy in the same route screen.
              All the above just to "hide the waypoints" haha!
              Huibertus LennyO 2 Replies Last reply
                Huibertus Offline
                Huibertus Offline
                Huibertus
                wrote on last edited by Huibertus
                @Stefan-Hummelink Pffff lijkt wel hogere wiskunde 😵
                • Huibertus Huibertus
                  @Huibertus said in In the Route Planner - how can I see a Route as a track?:
                  That is often the case with workarounds. 😜
                    LennyO Offline
                    LennyO Offline
                    @Stefan-Hummelink Thank you so very much for the clarification!
                    The workaround i figured out 🙂
                    But what I was missing from the suggestion of @RetiredWingMan is that I needed an empty screen and then add my route.
                    This is so simple and brilliant, that I did not think of it!
                    Thank you all for your wisdom!
                    This app is like a multi layered cake, where every layer is delicious if you know how to eat thru the previous one 🙂
                    Huibertus
                    Huibertus
                    • HERE maps updates
                      Alfred Schrittwieser
                      12.2k
                      1.4k
                      Bruno 7
                      Bruno 7
