  4. problem Zumo xt
problem Zumo xt
15 Posts 11 Posters 2.7k Views 5 Watching
  • terry durkinundefined Offline
    terry durkin
    Im trying to send routes to a Zumo xt but all i get is device not recognized, does anyone else have this problem
    TomOnTourundefined Mzokkundefined Don Staufferundefined Marinus van Deudekomundefined Stefan Martikkeundefined 7 Replies Last reply
    • terry durkinundefined terry durkin
      TomOnTourundefined Offline
      TomOnTour
      @terry-durkin
      cab you pleas let us know how you want to transfer it to your XT and when exactly you get the error message?
      Greetings
      Thomas
      MyRoute-APP Navigation Next (V5.0.3 - 449) on MDT665
      using iPad Pro (iPadOS 26.3) and Macbook Air (macOS 26.3)
        Mzokkundefined Offline
        @terry-durkin on my XT I download the routes to my phone and send them to the device via the Garmin Drive app.
          Don Staufferundefined Offline
          Don Stauffer
          @terry-durkin When using a PC or laptop, the most reliable method requires connecting to the XT using a USB cable. From the MRA app, use the 'export' feature. It requires a one-time installation of a connector app.
          Using the Garmin Drive app wirelessly works as well, but it can be glitchy. The USB method has worked for me every time. I use the GPX 1.1 file type.
          Good luck, MRA and the XT can be a very nice combination.
          Bouke Entundefined Nomko Nomdenundefined 2 Replies Last reply
          • Don Staufferundefined Don Stauffer
            Bouke Entundefined Offline
            @Don-Stauffer i agree
              @terry-durkin I use the drive app. Make sure your XT is online. That way it works perfect. It shouldn't make a difference but my experience is that it works best with the XT online
                Nomko Nomdenundefined Offline
                Nomko Nomden
                @Don-Stauffer said in problem Zumo xt:
                I'm using the MRA app on my phone and, after opening a route, i export it to my Zumo XT using the Drive app. Never had any issues!
                I also use the 1.1 GPX file type every time.
                | MRA Gold Member |
                | MRA Next + Kawasaki Z650 |
                • Nomko Nomdenundefined Nomko Nomden
                  @Nomko-Nomden that is exactly what I di. In theory of is possible to do it with the XT offline but I've experienced soms trouble and found that the routes were not send to the XT when it came on line.
                  Nomko Nomdenundefined 1 Reply Last reply
                    Nomko Nomden
                    @Marinus-van-Deudekom said in problem Zumo xt:
                    Maybe that's the problem in your case i assume?
                    I normally do it with the XT "online" so thsat i can transfer the routes directly to my XT through the Drive app. Never had any issues working like this. And i always usie 1.1 GPX, i did 1.2 but some routes work just fine but others i had issues with when navigating. So, 1.1 for me.
                    | MRA Gold Member |
                      @Nomko-Nomden thats what I said. My usual routine. Just indicated the other one to be complete
                      • Stefan Martikkeundefined Offline
                        Stefan Martikke
                        wrote on last edited by Stefan Martikke
                          Stefan Martikke
                          @terry-durkin
                          Hello, I have the same problem. The only thing that helps is removing the external memory card, then the XT is recognized at the Notebook and the transfer works.
                          Regards Stefan
                            Simon von Kaufmannundefined Offline
                            Simon von Kaufmann
                            I also had this problem as well trying to use the Web version of MyRoute-app. Some have given a partial answer but I would like to explain a bit more as I needed to work this out too. The Zumo is designed to interact with your mobile phone. So you need to download the My-route-app onto your mobile phone from the Appstore (I am using Apple ios) and then transfer the file to your Zumo using Garmin Drive. It will then come through as a track which you can convert to a route if you want to.
                            • CD130undefined Offline
                              Maybe as a workable alternative: Connect the zumo with the cable to your phone (use a data cable/adaptor for this) and use the files app to copy the GPX files.
                                @terry-durkin
                                Do you use a windows PC or a Mac?
                                Bouke Entundefined
                                Mzokkundefined
                                CD130undefined
                                Nomko Nomden
                                TomOnTourundefined
                                TomOnTour
                                Don Stauffer
                                Simon von Kaufmann
                                Stefan Martikke
                                terry durkin
                                • Free Ride Mode - Speed Warnings
                                  Urs Voegeleundefined
                                  Urs Voegele
                                • Carpuride zwart scherm
                                  De Ploey Georgesundefined
                                  De Ploey Georges
                                • Next+ 1st impressions
                                • Tracking rijden
                                • RideSleepRepeat – Your Biker Stays Across Europe
                                • MyRoute-App on the TomTom Rider
                                • MRA V5.0.3 (449) iOS Gebührenpflichtige Straßen Autobahn ??
