Specific Track v Route question exporting to tomtom go app
@M-Schrijver
As I mentioned earlier, I am not very interested in waypoints or POIs on my navigation screen. I rarely look at it and when I do look at the screen I just want to be able to quickly see how my route is going. I know my route and I don't need the navi to find a lunch or coffee location. I stop when I feel like it and start riding again when it suits me. My breaks are unplanned. I am also in the comfortable position that my motorcycle has a large tank and I do not easily run out of fuel. And that also applies to my (current) traveling companions.
Of course, this will be very different if you are going on a tour for a group, because there will probably be people who need all that information.
And I'll probably want that information when I'm older. But then the navi should probably also tell me why I'm on the bike and where I'm going. Because I keep forgetting that by then.
(Please see this comment as a comic note)@Jack-van-Tilburg said in Specific Track v Route question exporting to tomtom go app:
I totally agree with that mindset.
OK - as I have some experienced users and after having played a bit more and watched a few videos, I am left with a question, in view of the fact that when importing to tomtom it becomes a track and therfore loses its waypoints, I am left wondering why you might use so many when planning in MRA (and for example the option to expand the number of waypoints)
I guess the answer may be to brute force your sat nav to following the exact route as planned in MRA?
But then if I am planning on the tomtom map in MRA and using the same settings in totom go on my ios phone would it not follow the same route anywayThanks.!
@Grahame-Lancaster
A route and a track are two different things.
When using a route. You will using the TomTom routing algoritmes to calculate a route from point to point. When you use enough points in a route. The route will be identical. When you use to few points, the route can be different.When using a track. There is no calculation algoritme involved. TomTom Go just follows the track. With only one note. When importing a track in TomTom Go it will move the track line to existing roads. In theory this can causes some difference between the software you created the route in and TomTom GO. Normally when you create in MRA a route on the TomTom map Both MRA and TomTom Go are the same.
@Grahame-Lancaster
@M-Schrijver I kinda understand the differenc between route and track I think, but in tutorial videos, there has been the use of waypoints and expanding waypoints when using the tomtom map in MRA, if it gets converted to a track why bother. ?
@Grahame-Lancaster
To ensure that the route in MRA does not change when it is closed and/or reopened. That can happen due to various reasons.
Try to place as few waypoints as possible but as many as necessary. Consider, for example, places where the planner could take an unwanted "shortcut" or otherwise alternative route. -
@Grahame-Lancaster
Try to place as few waypoints as possible but as many as necessary. Consider, for example, places where the planner could take an unwanted "shortcut" or otherwise alternative route.@Jack-van-Tilburg ah, thank you, that explains it.
My opnion.
Just use tracks in TomTom Go. If a road is closed or some other rerouting, sometimes TomTom Go fixes this in advance (you won't notice this). Other times just follow the signs and TomTom will follow you and tries to guide you back to the original route (track).Waypoints don't add much functionality to your route compared to a track in TomTom Go.
In case of TomTom, the of waypoints in MRA (hand shape) doesn't have any functionality. Use only the shaping points (drop shape) the shape your route.
@M-Schrijver
Sounds like you don't need navigation at all
Yes I do. I don't have a swimming diploma because I get lost even in the swimmingpool
@Jack-van-Tilburg, Okay, good to have a real waterproof navigation device then
With your input, this post could be even better π
