  4. Roadblocking
Roadblocking
7 Posts 3 Posters 391 Views 2 Watching
  • Frank 8hundefined Offline
    Frank 8h
    I have a problem thatvarious street blockings are not considered (there is a few I discovered last weekend which should be closed for long time.....).
    Google maps shows them all. I read something of lists with POIs for such blockings. Is that the only work around? And if so, where do i get such a list?
    The traffic overlay does not show them at all.
    I have also streets in my area that are closed since years and will never open again - they are shown as open and can be used for routing.
    • Frank 8hundefined Frank 8h
      Rob Verhoeffundefined Offline
      @Frank-8h The link below allows you to submit changes to the map provider (Here):
      https://mapfeedback.here.com/#/report
      Frank 8hundefined 1 Reply Last reply
        Frank 8h
        @Rob-Verhoeff said in Roadblocking:
        That's nice and I did that for 2 streets, but honestly: there is so many roads that are currently closed due to weather (vosgues) and they show as open. Google maps shows as closed.
        Rob Verhoeffundefined Con Hennekensundefined 2 Replies Last reply
          @Frank-8h said in Roadblocking:
          For seasonal closures, you can choose 'Disable seasonal closures' from the menu. Here will not incorporate such changes. Only streets that for example no longer exist or have changed direction can be reported there.
            Frank 8h
            @Rob-Verhoeff Well, this doesn't change anything. I'm new into MRA but I expected to have better traffic data as advertised. rest seems really good. But closed roads are such a pain when you can't reach your destination without driving 2 hours more than expected....
              @Frank-8h, No one will ever offer better traffic information than Google. They monitor Android phones and can conclude from the absence of traffic that the road is closed. All others are dependent on local governments to submit data about road closures.
              The anecdote about this is that someone gathered all phones from friends and family, put it in a shopping cart and walked down the street. In about 5 minutes the road showed as jammed on Google Maps 🤣
              Must be one heck of a hefty road closure then...
                Frank 8h
                @Con-Hennekens 😊
                Well, maybe a bit exxagerated. But when I consider last weekend we even didn't reach our destination as expected.
                Frank 8hundefined
                Frank 8h
                • Waypoint / Viapoint Icons
                • Waypoints (Again!)
                • Clear Directions
                  Lex.Kloet.RXundefined
                  Lex.Kloet.RX
                • MRA is only speaking with French accent??
                • Scenic routing & RouteXpert library improvements
                  8.4k
                  Rainer Treichelundefined
                  Rainer Treichel
                • SilverFox Controller C 1
                  Arjan de Vriesundefined
                  Arjan de Vries
                  12.3k
                • Tracklog omzetten naar route geeft veel verschillen
                  Bouke Entundefined
