  3. Some advice please.
Some advice please.
32 Posts 13 Posters 18.2k Views 5 Watching
    @Drabslab said in Some advice please.:
    If you look for the cheapest solution then a Garmin or TomTom (500euro) is probably the way to go but these things slowly become outdated as their features are strictly limited to navigation.
    That's abou exactly what I DON'T think 😉 A decent Zumo is about €600, while a simple but good rugged phone can be had for less than half that, including a decent mount and an USB charger for it. On the other hand I think a Zumo is much less quickly outdated compared to an Android phone. Many people are still using Zumo 660 of almost 15 years old. I don't see that happening for any Android device 😉
    @richtea999 said in Some advice please.:
    If it's on a motorbike, then don't forget to add the Quad Lock anti-vibration mount
    I don't think that that is of any concern when you get a cheap rugged phone for your navigation needs only.
    @Con-Hennekens said in Some advice please.:
    You're right. But it depends on your demands.
    Yes, it still works but does it still gets mapupdates?
    I does not support traffic info.
    It is very slow compared to a phone.
    MRA Next does have features a Zumo 660 does not have. Even the new XT2 does not have these features.
    In my opnion a phone does give less bluetooth trouble than a dedicated GPS .
    A phone does not hold up for 15 year. But how often do you buy a new phone? What do you do with your old phone?
    The old phone is in many cases still perfect for use as a navphone on your motorcycle.
      @M-Schrijver, I agree with everyting. I was just noting one of the few advantages of a single-use dedicated GPS device 😉
      Theo Lammerts 1 Reply Last reply
        Theo Lammerts
        Theo Lammerts
        Theo Lammerts
        @Con-Hennekens Zijn er gebruikers die ervaringen hebben met één of meer van de volgende spullen. 5 of 7 inch schermen waarop zowel Carplay als Andoid auto en meer apps afgespeeld kunnen worden?
        • MAXCA C5 Pro Motorcycle Navigation Unit ( € 140) –
        • Ottocast lite C5 (260 USD)
        • Carpuride W702 IP6 € 250
        • Elebest Moeras navi C 750 € 210
        • BergGPS 5-inch Motornavigatie met Apple Carplay & Android Auto € 199,99
        Ik realiseer mij dat deze spullen in China geproduceerd worden (maar wat niet) en de kwaliteit niet altijd ok is. je (dure) iphone kan dan in je koffer/tanktas blijven zitten.
        • Theo Lammerts Theo Lammerts
          @Theo-Lammerts, ja die zijn er, maar daar ben ik er niet een van 😉
          Hier in het forum zitten vele gebruikers van zowel de carpuride als de Elebest, en volgens mij zijn die allemaal enthousiast over hun apparaat. Of dat specifiek om die toestellen gaat weet ik niet, want daar ben ik niet erg in thuis. Voor mij persoonlijk gaat er niks boven een native rugged android toestel die de app rechtstreeks draait zonder extra complexe tussenlaag. Dan kan je dure telefoon óók in jas/tanktas blijven zitten, en loopt die ook niet leeg.
            Theo Lammerts
            Theo Lammerts
            Theo Lammerts
            @Con-Hennekens Dank Cor, dat mijn vraag even op de juiste plek hebt gezet.
            • paul69
              hi @Paul-Johnson-5
              i recently sold my XT. and now only use a rugged tablet
              which cost £100 new, been using it for about 6-9 months now, it's an Oukitel RT3 and i have nothing running on the tablet save for the MRA next and a web browser to plan routes when away from home.
              i do not have a sim card fitted, if i need internet access away from home/hotel etc i use my phone as hotspot and this seems to work, and only use offline maps and offline navigation. this works perfectly well for me.
              i had to fashion a holder, which is attached to the original NAV 6 12mm bar, but it's secure and can be locked in place, a similar length of metal runs across the top and locks with a key on the back, powered from the usb socket next to the clocks.
              battery lasts many hours if not plugged in, i would even say all day. screen brightness has no issues.
              K1600 GTL
              iPhone 13 Pro, carpuride 702b
              Jörgen 1 Reply Last reply
              • paul69 paul69
                hi @Paul-Johnson-5
                @paul69 I am also a happy RT3 user, since April last year.
                Just for interest, can you make some more pictures of your holder?
                Thanks
                paul69 RetiredWingMan 2 Replies Last reply
                  Thanks
                  hi @Jörgen
                  i actually bought the RT3 after reading your thoughts on it, and yes i will take some photos tomorrow,
                  please don't laugh at my rubbish welding 🤣🤣✌️
                  K1600 GTL
                    Thanks
                    @Jörgen how do find the brightness of the RT3 in sunlight? The spec I saw only rated it at 400 while some other devices are as high as 1000. Thanks
                      @RetiredWingMan Hi, it is bright enough even with sunglasses, readable.
                      • paul69
                        #29
                        hi @RetiredWingMan
                        i agree with @Jörgen i have no issues with brightness, i have never not been able to see the screen,
                        not brilliant english there but you get the gist.
                        but for £100 you can't expect the screen resolution of £300+ devices
                        K1600 GTL
                        • paul69 paul69
                          hi @RetiredWingMan
                          @paul69 said in Some advice please.:
                          It is not so much about resolution but rather about the brightness your screen produces. My phone has a max of 530 Nits, and I can live with it but is certainly on the low side. A matte screenprotector can help. It lowers the brightness a bit but lowers the reflection of the sun even more. I have ordered such a thing recently, and will come back on it once received.
                          • paul69
                            hi @Con-Hennekens
                            i agree, but i should have written brightness not resolution. i had toyed with the idea of a matt screen protector but not had any issues yet. i might just buy one it can't do any harm
                            here you go @Jörgen
                            not brilliant photos but will give you an idea.
                            the black plastic attachment onto the 12mm bar is a generic fitment off ebay. it's not the most beautiful device, i was going to finish it off, have it powder coated etc but never got round to it. the salt on the roads over here in the UK destroys all things metal.
                            i was going to buy a generic tablet holder and somehow attach that to the bike, but i thought i would just try my own first
                            K1600 GTL
                            • paul69 paul69
                              hi @Con-Hennekens
                              here you go @Jörgen
                              @paul69 thanks for showing. Mine looks similar, but without key
                              • paul69 paul69 referenced this topic on
                              Theo Lammerts
                              Theo Lammerts
                              Paul Johnson 5
                              Paul Johnson 5
                              Peter Greenacres
                              Peter Greenacres
                              scott vallance 0
                              scott vallance 0
                              Jose Pinheiro 0
                              Jose Pinheiro 0
                              • Map lock
                                tfdahazellgmail.com
                                tfdahazellgmail.com
                              • Beta abonnement
                                BMW1300GSA
                                BMW1300GSA
                                2.3k
                                Gerard van der Veer
                                Gerard van der Veer
                              • Uitnodiging
                                Hanza 0
                                Hanza 0
                                Hans Kremers
                                Hans Kremers
                              • SilverFox Controller C2
                                Hans Lamers
                                Hans Lamers
