  3. Distance & time along a Route
7 Posts 3 Posters 2.1k Views
  • Craig 4
    Craig 4
    Craig 4
    Hi, once you have planned a route is there a way to see the distance and time to a certain point on the route? i.e. if I planned a 5 hour ride, set off at 10am and want to plan a stop for dinner say at 1pm, is there a way to see where i would roughly be at that time? Hopefully this makes sense, I've seen something like this on other route planners, you hover your cursor over a point in the route and it gives you distance and time. Thanks.
    • Craig 4 Craig 4
      @Craig-4 Hi Craig, In the routepoints/waypoints overview in the 'big' menu bar left of the map, you can see the distance and time up to every routepount/waypoint. If you find your target to land between two waypoints, just add another waypoint and move it until you've found the target time/distance. You need to calculate though for a certain time target:
      I.e: You start at 10:00, lets say waypoint 30 is at 100km/3h10, then with a margin you end up at that waypoint at 13:10.
      • Arno van Lochem - Senior RX
        In addition to Stefan: Make the restaurant poi's visible and find a nice restaurant near your chosen waypoint.
        • Arno van Lochem - Senior RX Arno van Lochem - Senior RX
          @Arno-van-Lochem Yes indeed, I suggest also to turn on the cafe/pub POI since I've found that not always the restaurant or cafe is put into the correct category. I usually check the POI's with Google Hybrid overlay to confirm the intended restaurant/cafe. 🙂
            wrote on last edited by Arno van Lochem - Senior RX
            When I plan a stop somewhere, I always check in Google if the restaurant still exists. And whether it will, for example, not open until 5 pm. Those kind of things.
              @Arno-van-Lochem Yes, exactly that. I did the same thing for a trip to the Eifel coming August and found that the POI and Google Hybrid data did not match the actual restaurant based on address. Nice.
              • Craig 4
                Craig 4
                Craig 4
                That's brilliant, thank you all for your help.
                Craig 4
                Craig 4
                • Kaart niet zichtbaar
                  Bé Jeuring
                  Bé Jeuring
                • Xpert overlay not clear
                  Corrado Miniati 0
                  Corrado Miniati 0
                • Google maps
                  Ed Bos 0
                  Ed Bos 0
                • Trains like Ferries?
                  Corrado Miniati 0
                  Corrado Miniati 0
