  4. "The selected mode...
3 Posts 3 Posters 1.1k Views 3 Watching
  • Montorsi Paolo 0undefined Offline
    Montorsi Paolo 0
    ...only works with the HERE / TomTom map."
    I have some routes showing this error each time I open them.
    Whats wrong?
    Thanks
    Rob Verhoeffundefined Corjan Meijerinkundefined 2 Replies Last reply
    • Montorsi Paolo 0undefined Montorsi Paolo 0
      Whats wrong?
      Thanks
      Rob Verhoeffundefined Online
      @Montorsi-Paolo-0 This is your issue: you created the route based on OpenStreetMap. Instead, choose the Here or TomTom map. However, navigation always takes place based on the Here map. So, for creating your routes, it's better to use that map.
      You can save the Here map as the default map by checking the box on the bottom line:
      Last but not least: you need a gold subscription to do that!
        Whats wrong?
        Thanks
        @Montorsi-Paolo-0 to add to @Rob-Verhoeff if this happens on all the routes you create, just select a different default travel mode (from your account settings).
        The walk / cycle / drive modes work in all maps 🙂
        Montorsi Paolo 0
          16.7k
          Andre Klapundefined
          Andre Klap
        • App behaviour when in offline mode at a construction site
        • No roads found when trying to navigate route in Japan
        • Finetunen van herberekenen zou fijn zijn.
        • Identifying an expert route without hunting for the start point
        • New device …. how to change registered devices?
        • Ik was dit weekend 4 dagen aan het touren met MRA, maar had een groot probleem.
