  3. Route - Navigationsberechnung
12 Posts 5 Posters 2.8k Views 3 Watching
  • Kronlandundefined Offline
    Kronland
    Guten Morgen allerseits,
    wie kann ich bei my Route die Art der Navigation einstellen.
    Kürzere Strecke
    Schnellere Route
    etc. etc.
    Danke für die Hilfe.
    lg aus der Steiermark
    Joachim
    • Jörgenundefined Offline
      Hallo,
      einfach nach Aufrufen der Route die entsprechende Einstellung hier wählen:
      Der Strich für die schnellste, der Rest für Kurvig.
      Kronlandundefined 1 Reply Last reply
      • Jörgenundefined Jörgen
        Hallo,
        Kronland
        @Jörgen
        Habe mich wahrscheinlich falsch ausgedrückt. Geht um die Planung.
        Hier finde ich diese Einstellung nicht, somit verrechnet er doch etwas komisch.
        zur Info: Gold User
        lg
        Joachim
        • Kronlandundefined Kronland
          Kürzere Strecke
          Schnellere Route
          etc. etc.
          Joachim
          Rob Verhoeffundefined Online
          @Kronland That is only possible if you use the Here map or the TomTom map to plan your route, and additionally, only in the travel modes for car, camper, and truck. In the Toolkit menu, you will find the option 'Route optimization.' There, you can choose between the shortest or fastest route.
          It's likely that you have selected the motorcycle travel mode. Within that travel mode, this optimization is not available.
            Kronland
            @Rob-Verhoeff Thanks,
            i want to plan a Route for motorcycle.
            Do you know the difference between car an motorcycle route options?
            Joachim
              Jack van Tilburg
              @Kronland
              There are almost no differences.
              But if you use "Transport mode motorcycle", restrictions implemented by the road authority and reported to the relevant map supplier are taken into account during planning.
              And it also has some disadvantages. See the screenshot as an example.
              With motorcycle mode enabled you will be redirected to a restriction that applies on Saturdays and Sundays. But the road is open for motorcycles from Monday to Friday.
                Joachim
                @Kronland
                Motorcycle is always the fastest option, Car you can choose between fastest and shortest via the toolkit
                  @Kronland
                  @Hans-van-de-Ven-MRA-Master I doubt that. In the example of @Jack-van-Tilburg above, when I navigate the route as "car," I can choose between the fastest and shortest options. Both take the same short direct connection between waypoint 1 and waypoint 2. If I choose "motorcycle", the route takes almost twice as long. That is not the shortest route then!
                    @Rob-Verhoeff
                    That is because that road is closed fot motorcycles in the weekend
                    Rob Verhoeffundefined Jörgenundefined 2 Replies Last reply
                      @Rob-Verhoeff
                      @Hans-van-de-Ven-MRA-Master Ha, you beat me 😉 This 'seasonal'-weekendclosing is not known to Here then...
                      I do use your closures for the Netherlands. I've to look into the foreign closures also!
                        @Rob-Verhoeff
                        That are forbidden for motorcycles, click!
                          @Rob-Verhoeff
                          @Hans-van-de-Ven-MRA-Master said in Route - Navigationsberechnung:
                          That is the reason I use this nice street only during a week. 😊
                          But back to the question from Joachim.
                          Zur Planung von schönen Touren, gehst du in das Routenlabor und machst deine Einstellungen für eine Scenic Tour.
                          Das geht für eine Rundtour oder eine A zu B Tour.
                          Jack van Tilburg
                          Kronlandundefined
                          Kronland
                            Huibertusundefined
                            Huibertus
                            haweboundefined
                            hawebo
                            John S Parryundefined
                            8.0k
                          • Updated beta! 5.2.1 (486)
                            652
                          • Android auto en geluid
