  4. Duplicate POIs
Duplicate POIs
13 Posts 4 Posters 96 Views 1 Watching
  • Jeremy Palmer Jeremy Palmer
    @Jack-van-Tilburg
    Yes, MRA Nav app. on iPhone SE 2020 running latest version.
    (Thank you for replying 👍).
    Jeremy Palmer Offline
    Jeremy Palmer
    @Jeremy-Palmer
    Sincere apologies, the error is when using MRA website.
    Sorry to confusion.
      @Jeremy-Palmer
      Do you mean using MRA Navigation?
      Because you say:
      These only appeared when using HERE/default Gold/Nav maps.
      But you can only use the Here map with MRA Nav.
      Jeremy Palmer
      @Jack-van-Tilburg
      Sincere apologies - I meant when using MRA website.
      [link text](link url)
        @Jack-van-Tilburg
        Jack van Tilburg Offline
        Jack van Tilburg
        @Jeremy-Palmer
        Would you please share a link to the route using the "Share" function in the Page Menu?
        Make sure the privacy setting is set to 'Public'
        Jeremy Palmer 1 Reply Last reply
          @Jeremy-Palmer
          Jeremy Palmer
          @Jack-van-Tilburg
          Link shared, Jack
          Jack van Tilburg Hans van de Ven MR.MRA 2 Replies Last reply
            @Jack-van-Tilburg
            Link shared, Jack
            Jack van Tilburg
            @Jeremy-Palmer
            Okay thanks.
            But I expected to find the link here in this topic 🙂
            Maybe it is this one?
            https://www.myrouteapp.com/en/social/route/8374972?mode=share
            But then you have to explain in more detail what the problem you mean is because I don't immediately see anything strange. 😞
              @Jeremy-Palmer
              Okay thanks.
              @Jack-van-Tilburg, If you look closely at the screenshot above, you will notice that there POI (not real POI but map-layer icons) that are visible twice with a short distance.
              Strange indeed, but most likely a map error.
              • Con Hennekens Offline
                The Cock Horse...? 🤣
                  Jack van Tilburg
                  Yep, a pretty dubious environment there. 😀
                    Jack van Tilburg
                    By the way, those double symbols are bus stops.
                    One on the left and one on the right of the road.
                      @Jack-van-Tilburg
                      Link shared, Jack
                      @Jeremy-Palmer
                      I think you are using the OSM map, because the segments icons are only available in the OSM map.
                      The POI's that you see on the map is Map Data.
                      Jack van Tilburg
                      Jack van Tilburg
                      Jeremy Palmer
                      Jeremy Palmer
                        Bruno 7
                        Bruno 7
                      • How do i export or 'save as' a file into Garmin Camper 770 - Help
