  4. Duplicate POIs
Duplicate POIs
13 Posts 4 Posters 97 Views 1 Watching
  • TorqueRider TorqueRider
    @Jeremy-Palmer
    Do you mean using MRA Navigation?
    Because you say:
    These only appeared when using HERE/default Gold/Nav maps.
    But you can only use the Here map with MRA Nav.
    Jeremy Palmer
    Jeremy Palmer
    Jeremy Palmer
    @Jack-van-Tilburg
    Yes, MRA Nav app. on iPhone SE 2020 running latest version.
    (Thank you for replying 👍).
    Jeremy Palmer 1 Reply Last reply
    • Jeremy Palmer Jeremy Palmer
      @Jack-van-Tilburg
      Jeremy Palmer
      Jeremy Palmer
      Jeremy Palmer
      @Jeremy-Palmer
      Sincere apologies, the error is when using MRA website.
      Sorry to confusion.
        @Jeremy-Palmer
        Because you say:
        Jeremy Palmer
        Jeremy Palmer
        Jeremy Palmer
        @Jack-van-Tilburg
        Sincere apologies - I meant when using MRA website.
        [link text](link url)
          @Jack-van-Tilburg
          @Jeremy-Palmer
          Would you please share a link to the route using the "Share" function in the Page Menu?
          Make sure the privacy setting is set to 'Public'
            @Jeremy-Palmer
            Jeremy Palmer
            Jeremy Palmer
            Jeremy Palmer
            @Jack-van-Tilburg
            Link shared, Jack
            TorqueRider HABVEN aka MrMRA 2 Replies Last reply
              @Jack-van-Tilburg
              Link shared, Jack
              @Jeremy-Palmer
              Okay thanks.
              But I expected to find the link here in this topic 🙂
              Maybe it is this one?
              https://www.myrouteapp.com/en/social/route/8374972?mode=share
              But then you have to explain in more detail what the problem you mean is because I don't immediately see anything strange. 😞
                @Jeremy-Palmer
                Okay thanks.
                @Jack-van-Tilburg, If you look closely at the screenshot above, you will notice that there POI (not real POI but map-layer icons) that are visible twice with a short distance.
                Strange indeed, but most likely a map error.
                • MotoCon
                  The Cock Horse...? 🤣
                    Yep, a pretty dubious environment there. 😀
                      By the way, those double symbols are bus stops.
                      One on the left and one on the right of the road.
                        @Jack-van-Tilburg
                        Link shared, Jack
                        @Jeremy-Palmer
                        I think you are using the OSM map, because the segments icons are only available in the OSM map.
                        The POI's that you see on the map is Map Data.
                        Jeremy Palmer
                        Jeremy Palmer
                          Michael 2v
                          Michael 2v
                        • Hide warnings on the map
                        • Map Layers
                          Martin White
                          Martin White
                        • Bollard trouble
