  4. Tracking stops
Tracking stops
19 Posts 6 Posters 201 Views 3 Watching
    @Hans-van-de-Ven-MRA-Master When driving a route, the tracking is automatically started if you have configured it that way in the menu. Only when driving an A-B route you can pause the track, and it doesn't automatically resume after the pause, I believe. It depends on what type of navigation TS initiated... a route with waypoints or an A-B route?
    @Rob-Verhoeff
    You can also pause the track when driving a route
    MotoCon Rob Verhoeff 2 Replies Last reply
      @Rob-Verhoeff
      @Hans-van-de-Ven-MRA-Master, yes you can. But auto-tracking-start only works for planned routes. You can start tracking on A2B routes as well, and of course you can pause them. They just will not auto-resume. If you manually start the tracking function, you will also have to resume it manually.
        I know šŸ˜‰
          @Rob-Verhoeff
          @Hans-van-de-Ven-MRA-Master but then it wil auto-resume if initiated in the menu. That's why it is interesting to know wat TS is navigating, a route or A2B and what his configuration is.
          šŸ’» Routelab on MacBook Air & iMac (Golden Gate & Ventura)
          Rod Sydenham 1 Reply Last reply
            Rod Sydenham
            Rod Sydenham
            Rod Sydenham
            @Rob-Verhoeff
            I was not using my phone to navigate. I was only using it to create a track as I rode. I started the tracking function when I first started in the morning and did not touch any controls all day. This was not the first time it happened. I posted the one I did as an example.
            Here are a couple more.
            Rob Verhoeff RetiredWingMan HABVEN aka MrMRA 3 Replies Last reply
            • Rod Sydenham Rod Sydenham
              @Rob-Verhoeff
              @Rod-Sydenham That is clear then. Or perhaps there's poor GPS reception in that area?
                @Rob-Verhoeff
                @Rod-Sydenham I've seen issues like that when I did not have Internet access.
                • Rod Sydenham
                  Rod Sydenham
                  Rod Sydenham
                  @Rob-Verhoeff
                  My Garmin InReach worked fine as did Osmand tracking.
                    Rod Sydenham
                    Rod Sydenham
                    Rod Sydenham
                    @Rob-Verhoeff
                    If you need internet access for tracking, it pretty much negates the usefulness of the tracking features in a lot of cases.
                    Corjan Meijerink Rob Verhoeff 2 Replies Last reply
                      @Rob-Verhoeff
                      @Rod-Sydenham tracking is independent of internet.
                        @Rob-Verhoeff
                        @Rod-Sydenham
                        Is your phone mounted on your motorcycle or do you put it in your tank bag or do you put it in your jacket?
                        I suspect that the pause button is activated somehow
                          @Rob-Verhoeff
                          @Rod-Sydenham I was refering to GPS reception not internet.
                            Rod Sydenham
                            Rod Sydenham
                            Rod Sydenham
                            @Rob-Verhoeff
                            I had the phone in my jacket packet. It was running both Myroute tracking and Osmand tracking. My InReach was also in my pocket. Both the Inreach and Osmand worked fine and did not have the gaps the Myroute track did. I don't think GPS reception is the issue.
                              @Rod-Sydenham
                              Rod Sydenham
                              Rod Sydenham
                              Rod Sydenham
                              That would make sense but at the end of each day when I shut the tracking down, it still appeared to be running.
                                @Rod-Sydenham, Probably the result of aggressive battery savings by your OS. I would check that on a per app basis.
                                  Rod Sydenham
                                  Rod Sydenham
                                  Rod Sydenham
                                  I checked the battery saving settings for Myroute. They are the same (off) as they are for Osmand. Osmand tracked on the roads I rode so I don't think it was that.
                                  I will continue to monitor it although now that winter has set in here, I won't have much opportunity.
                                  Rod Sydenham
                                  Rod Sydenham
                                    Michael 2v
                                    Michael 2v
                                  • Hide warnings on the map
                                  • Map Layers
                                    Martin White
                                    Martin White
                                  • Bollard trouble
