  4. Tracking stops
Tracking stops
19 Posts 6 Posters 201 Views 3 Watching
  • Rod Sydenham
    Rod Sydenham
    Rod Sydenham
    Tracking will shut down for no reason. The phone is on, track is recorded for quite a while and then stops. Anyone else experience this.
    Here is an example
    • Rod Sydenham Rod Sydenham
      Here is an example
      @Rod-Sydenham
      I suspect that you have accidentally paused the tracklog, when saving the tracklog you will get a straight line from where the tracklog is paused to the point where it is saved and restarted.
        @Rod-Sydenham
        @Hans-van-de-Ven-MRA-Master When driving a route, the tracking is automatically started if you have configured it that way in the menu. Only when driving an A-B route you can pause the track, and it doesn't automatically resume after the pause, I believe. It depends on what type of navigation TS initiated... a route with waypoints or an A-B route?
          @Rob-Verhoeff
          You can also pause the track when driving a route
          Con Hennekens Rob Verhoeff 2 Replies Last reply
            @Rob-Verhoeff
            @Hans-van-de-Ven-MRA-Master, yes you can. But auto-tracking-start only works for planned routes. You can start tracking on A2B routes as well, and of course you can pause them. They just will not auto-resume. If you manually start the tracking function, you will also have to resume it manually.
              I know šŸ˜‰
                @Rob-Verhoeff
                @Hans-van-de-Ven-MRA-Master but then it wil auto-resume if initiated in the menu. That's why it is interesting to know wat TS is navigating, a route or A2B and what his configuration is.
                Rod Sydenham 1 Reply Last reply
                  Rod Sydenham
                  Rod Sydenham
                  Rod Sydenham
                  @Rob-Verhoeff
                  I was not using my phone to navigate. I was only using it to create a track as I rode. I started the tracking function when I first started in the morning and did not touch any controls all day. This was not the first time it happened. I posted the one I did as an example.
                  Here are a couple more.
                  Rob Verhoeff RetiredWingMan Hans van de Ven MR.MRA 3 Replies Last reply
                    @Rob-Verhoeff
                    @Rod-Sydenham That is clear then. Or perhaps there's poor GPS reception in that area?
                      @Rob-Verhoeff
                      @Rod-Sydenham I've seen issues like that when I did not have Internet access.
                      • Rod Sydenham
                        Rod Sydenham
                        Rod Sydenham
                        @Rob-Verhoeff
                        My Garmin InReach worked fine as did Osmand tracking.
                          Rod Sydenham
                          Rod Sydenham
                          Rod Sydenham
                          @Rob-Verhoeff
                          If you need internet access for tracking, it pretty much negates the usefulness of the tracking features in a lot of cases.
                          Corjan Meijerink Rob Verhoeff 2 Replies Last reply
                            @Rob-Verhoeff
                            @Rod-Sydenham tracking is independent of internet.
                              @Rob-Verhoeff
                              @Rod-Sydenham
                              Is your phone mounted on your motorcycle or do you put it in your tank bag or do you put it in your jacket?
                              I suspect that the pause button is activated somehow
                                @Rob-Verhoeff
                                @Rod-Sydenham I was refering to GPS reception not internet.
                                  Rod Sydenham
                                  Rod Sydenham
                                  Rod Sydenham
                                  @Rob-Verhoeff
                                  I had the phone in my jacket packet. It was running both Myroute tracking and Osmand tracking. My InReach was also in my pocket. Both the Inreach and Osmand worked fine and did not have the gaps the Myroute track did. I don't think GPS reception is the issue.
                                    @Rod-Sydenham
                                    Rod Sydenham
                                    Rod Sydenham
                                    Rod Sydenham
                                    That would make sense but at the end of each day when I shut the tracking down, it still appeared to be running.
                                      @Rod-Sydenham, Probably the result of aggressive battery savings by your OS. I would check that on a per app basis.
                                        Rod Sydenham
                                        Rod Sydenham
                                        Rod Sydenham
                                        I checked the battery saving settings for Myroute. They are the same (off) as they are for Osmand. Osmand tracked on the roads I rode so I don't think it was that.
                                        I will continue to monitor it although now that winter has set in here, I won't have much opportunity.
                                        Rod Sydenham
                                        Rod Sydenham
                                          peha
                                          peha
                                        • Using tracks
                                        • Kan keuze voor voertuigbeperking worden ' onthouden' ?
                                          Kirsten De Weerd
                                          Kirsten De Weerd
                                        • Frozen marker.
