  3. [App-Beta] Announcements
  4. New Beta! (v4.0.3) Motorhome & Motorcycle
59 Posts 16 Posters 796 Views 4 Watching
  • Arno 0 Arno 0
    If you turn off the use of toll roads while in camper transport mode, it also turns off the use of highways. This is only in camper transport mode and not in car or motorcycle transport mode.
    @Arno-0 thanks! I believe the app does it correctly, might be something with HERE! Iโ€™ll check next week ๐Ÿ™‚
    Arno 0 1 Reply Last reply
      Arno 0
      Arno 0
      Arno 0
      wrote on last edited by Arno 0
      #42
      @Corjan-Meijerink Thanks that you will check. The problem is in the app.
      • Arno 0 Arno 0
        @Arno-0 Iโ€™ll let you know ๐Ÿ˜‰
          Arno 0
          Arno 0
          Arno 0
          #44
          @Corjan-Meijerink Iโ€™ve just checked and itโ€™s a problem in both the MRA Next app and in the MRA Routeplanner. Thanks for letting me know ๐Ÿ‘
          • Arno 0 Arno 0
            @Arno-0 that is interesting info! Then it will most likely be an issue with HERE as our app and website are very different implementations of HERE ๐Ÿ™‚
              @Rolf-Engelsman Dank voor het delen - de gegevens komen direct uit HERE! ๐Ÿ™‚ Wij hebben hier verder geen invloed op helaas.
              Fouten kunnen hier gemeld worden: https://mapfeedback.here.com/#/report Grappig dat het een berucht punt is. Dan is HERE niet de enige met onjuiste gegevens.
              Rolf Engelsman
              Rolf Engelsman
              Rolf Engelsman
              @Corjan-Meijerink bedankt voor je reply. Ik heb dit gemeld via jouw linkje.
              BMW R1250RT
              • Nick Carthew
                The thinner yellow track line is a great improvement. The blue route line is visible when travelling along a previously used road. Thanks @Corjan-Meijerink ๐Ÿ‘
                  A quick statement about the app ignoring highways while using the camper mode and you are avoiding tolls only.
                  I've reached out to HERE and got the following response:
                  Thank you for reaching out to us.
                  After having ran a quick check with our refClient, I'm also a bit surprised about the behavior and cannot imagine that this is really working as expected.
                  I will create an internal case with our Routing Team and address this issue to them.
                  Once I have news, I'll let you know.
                  TLDR; The issue is with HERE and will hopefully be resolved very quickly!
                  @Arno-0 thanks for reporting!
                    @Nick-Carthew thank you. I'll have to play with the zoom setting to see what the impact is. I always felt that the zoom level was too high allowing a look down the road of only about 300 m. I prefer 1 to 2 km.
                    I look forward to a time when certain settings, such as route options (avoid options for example), can be saved and automatically loaded based on selected travel mode. I tend to use different options when traveling by car vs motorcycle.
                    @Doug-Robinson completely agree. 300m at 60 kph (stated in a comment above) may be enough, however, not at 100 kph or more.
                    Knowing the distance each click of the zoom (in or out) is, would be helpful knowledge as well.
                    • Edgar Hofer
                      Edgar Hofer
                      Edgar Hofer
                      Hey Leute
                      Ich bin gerade auf einer Motorradreise durch Sรผdfrankreich und habe leider, einen Tag vor der Abreise, auf die Version 4.0.3 ein Update gemacht.
                      Leider musste ich feststellen, dass die NEUE Art der Wegpunktdarstellung fรผr mich absolut keinen Sinn macht. Beispiel: Zufahrt zu einem StraรŸenpass. Ich setze einen Wegpunkt mit dem Namen des StraรŸenpass. Ab der letzten, mรถglichen Abzweigung war es mir wichtig, laufend die Entfernung und den Namen des Wegpunktes auf dem Display zu haben. Eine Anweisung, fรผr eine Abzweigung, die mitunter mehrere Kilometer hinter dem Wegpunkt stattfindet, ist noch vรถllig unwichtig.
                      Bei CarPlay habe ich feststellen mรผssen, dass es รผberhaupt keine Informationen mehr zu Wegpunkten gibt.
                      Also fรผr mich ist es ganz wichtig, dass bei der nรคchsten Version die ALTE Wegpunktdarstellung als Option wieder verfรผgbar ist.
                      Da ich mit der Version 4.0.3 รผberhaupt nicht klargekommen bin, habe ich gestern ein downgrade auf die Version 4.0.2 gemacht und fahre mit dieser Version den Urlaub weiter.
                      • Edgar Hofer Edgar Hofer
                        Hey Leute
                        #51
                        @Edgar-Hofer, If I understand you correctly, you want to have the name of the next WP available at all times, although that name is equal to the name of the street it was placed on?
                        There are different ways to show the names of streets.
                        A: street you are on
                        B: street you are going to
                        Both can be enabled / disabled from settings:
                        There was a lot of criticism on the forum on the old way of presenting the WP's. It was blocking the next instruction. Therefore I don't think the old way will be restored.
                        A method to overcome this could be to place a WP with the name "Start <Namen des StraรŸenpass>" at the beginning of that pass. Similar you could place an "Ende <Namen des StraรŸenpass>" at the end of it. That way you get even more information than in your current method?
                        Edgar Hofer 1 Reply Last reply
                        • Arjan de Vries
                          Arjan de Vries
                          Arjan de Vries
                          Yes! Tankstations on the route!! I have been missing that on my ZUMO XT.
                            Edgar Hofer
                            Edgar Hofer
                            Edgar Hofer
                            wrote on last edited by Edgar Hofer
                            #53
                            MRA-Routenplaner und MRA-Navigation sollte doch eigentlich eine Symbiose sein. Ich plane mit MRA-Routenplaner schรถne Routen, oder verwende Routen von der RouteXpert Bibliothek. Auch ich habe dafรผr schon Routen verรถffentlicht.
                            Bei der Routenplanung werden doch Wegpunkte (Via oder Shaping) gesetzt, beschriftet (Pause, Kaffee, Viewing Pointโ€ฆ) usw. Und genau das ist bzw. war doch der groรŸe Vorteil und die Stรคrke von MRA-Navigation. Ich bekomme diese Informationen wรคhrend der Fahrt. Anweisungen fรผr die nรคchste Abzweigung usw. das kann jedes Navi. Da reicht ein TomTom, Garmin oder auch ein billiges von jedem Diskonter. Auch Informationen fรผr die nรคchste Tankstelle kann inzwischen jedes Navi. Sogar mein Navi auf der Harley Davidson.
                            Wenn ich Sie richtig verstehe, mรถchten Sie, dass der Name des nรคchsten WP jederzeit verfรผgbar ist, obwohl dieser Name mit dem Namen der StraรŸe รผbereinstimmt, auf der er platziert wurde?
                            Nein, ich mรถchte nicht das der nรคchste WP immer verfรผgbar ist. Ich mรถchte aber, das der nรคchste WP dann verfรผgbar ist, wenn keine Richtungsanweisung bis zu diesem WP mehr besteht.
                            Beispiel: Ich fahre auf einer 20km langen PanoramastraรŸe. Ich habe mir im Routenplaner mehrere Viewing Point, evtl. eine Kaffeepause als WP markiert. Die Anzeige (Name und Entfernung) dieser WP haben doch Vorrang, gegenรผber einer Anweisung, die weit hinter dieser PanoramastraรŸe liegt. Diese Anweisung benรถtige ich erst dann, wenn der letzte WP passiert worden ist.
                            Die Option nur bestimmte WP (Via โ€“ Shaping, bestimmte Farben) anzuzeigen, wรคre natรผrlich optimal.
                            Im Forum gab es viel Kritik an der alten Art der Prรคsentation der WP's. Es blockierte die nรคchste Anweisung. Daher glaube ich nicht, dass der alte Weg wiederhergestellt wird.
                            Jene die hier Kritik geรคuรŸert haben, wollen MRA-Routing so verwenden, wie sie es von den anderen Navigationsgerรคten her kennen. Startpunkt โ€“ Endpunkt evtl. noch ein oder zwei Zwischenpunkte setzen und die Route ist fertig. Fรผr diese Routen brauche ich kein MRA-Next !
                            Eine Mรถglichkeit, dies zu umgehen, kรถnnte darin bestehen, einen WP mit dem Namen โ€žStart <Namen des StraรŸenpass>โ€œ am Anfang dieses Passes zu platzieren. Ebenso kรถnnte man am Ende ein โ€žEnde <Namen des StraรŸenpass>โ€œ platzieren. Dadurch erhalten Sie noch mehr Informationen als bei Ihrer bisherigen Methode?
                            Ist keine Option! Die Entfernung zum nรคchsten WP wird nicht angezeigt! Xpert Routen mรผsste auch umgeschrieben werden.
                            Wie gesagt, ich bin derzeit in Sรผdfrankreich unterwegs und werde mal bis zum Ende meiner Rundfahrt mit der Version 4.0.2 weiterfahren. Stรผrzt zwar ab und zu mal ab, aber funktioniert trotzdem besser als 4.0.3
                            Lg
                            Edgar
                              Lg
                              Edgar
                              @Edgar-Hofer, distance to the next waypoint is also available in the waypoint tile on the top right. You can try to hold on to your old method, or embrace the new possibilities. That Xpert routes have been made in a certain way, is no reason to hold back on innovation. Besides I don't think many people use your method, so rewriting is not really needed.
                              Please, if you copy text into a message, do it in plain text, and keep it a quote (being a ">" in front). That makes your text a lot better readable. Besides it is not really beneficial to copy an entire message (even if it's in a different language).
                              • CD130
                                Mijn Duits is niet heel best, maar OpenAI maakte er dit van:
                                "Bijvoorbeeld: Ik rijd op een 20 km lange panoramische route. Ik heb meerdere uitzichtpunten en mogelijk een koffiepauze gemarkeerd als waypoints in de routenplanner. De weergave (naam en afstand) van deze waypoints heeft voorrang boven een instructie die ver achter deze panoramische route ligt. Deze instructie heb ik pas nodig als het laatste waypoint is gepasseerd.
                                De optie om alleen bepaalde waypoints (Via - Shaping, bepaalde kleuren) weer te geven, zou natuurlijk ideaal zijn."
                                Opzich vind ik dit wel een goed punt... Wanneer je volgende punt een koffiestop of een uitkijkpunt o.i.d. is, dan is de info voor de volgende afslag (die in dit voorbeeld dus achter de stop ligt) niet echt relevant. Met deze update zijn er bepaalde afstanden ingesteld waarop de waypoints of shaming points worden weergegeven. Veel beter dan het was, maar vind bovenstaande wel de moeite om goed naar te kijken. Of begrijp ik het niet goed?
                                • CD130 CD130
                                  @CD130 said in New Beta! (v4.0.3) Motorhome & Motorcycle:
                                  Dat kan toch al in build 4.0.3 - 209? Of begrijp ik het ook niet ๐Ÿ™ƒ
                                  ๐Ÿ’ป Routelab on MacBook Air & iMac (Golden Gate & Ventura)
                                  CD130 1 Reply Last reply
                                    wrote on last edited by CD130
                                    #57
                                    @Rob-Verhoeff je krijgt ze inderdaad te zien, maar op deze manier:
                                    @Corjan-Meijerink said in New Beta! (v4.0.3) Motorhome & Motorcycle:
                                    You can choose if waypoint info needs to be displayed (off / via / all) and when done so, it will be displayed like above. For viapoints the title / description will be shown when within 2km and for shaping points, when you are within 750m.
                                    Op een rechte weg van 20 km, met halverwege een waypoint krijg je nu de eerste 8km de aanwijzing te zien van voor aan het einde van deze 20km weg en pas 2km voor het waypoint komt deze beeld. Het zou mooi zijn als het waypoint gelijk aan het begin van deze weg in beeld komt. Althans, ik denk dat @Edgar-Hofer dat bedoelt. Denk dat dit qua programmeren niet heel eenvoudig is. Persoonlijk zie ik er wel voordeel in, maar ben al super blij met de huidige werking ๐Ÿ™‚ Het kan natuurlijk ook zijn dat ik Edgar niet goed heb begrepen en/of de huidige werking niet goed uitleg. Ik moet het zelf eerdaags ook gewoon even lekker rustig gaan testen ๐Ÿ™‚
                                    • CD130 CD130
                                      @CD130, het idee was juist dat de aankondiging van een waypoint de informatie over de volgende instructie daarachter blokkeert, en dat dat onwenselijk is. Daarom is dat aangepast. Als je een koffiestop nadert, maak je daar een VIA point van, dan krijg je 2km van te voren dit al in beeld. Dat is toch prima?
                                        @Con-Hennekens Denk dat het inderdaad prima is zo. Zal het even moeten ervaren in de praktijk. Heb eerdaags een route gepland staan. Even volpompen met koffiestops maar ๐Ÿ˜‰
                                        Rolf Engelsman
                                        Rolf Engelsman
                                        Arjan de Vries
                                        Arjan de Vries
                                        Arno 0
                                        Arno 0
                                        Edgar Hofer
                                        Edgar Hofer
                                        • Hide warnings on the map
                                        • Map Layers
                                          Martin White
                                          Martin White
                                          Michael 2v
                                          Michael 2v
                                        • Bollard trouble
