  3. Shaping points and waypoints in Zumo XT2
4 Posts 2 Posters 1.5k Views 1 Watching
  • Kenneth de Miranda
    Kenneth de Miranda
    Kenneth de Miranda
    Hi all, I’m using the Zumo XT2, Tread and MRA for route planning. I use various methods to get my MRA routes on the XT2, the easiest being downloading a MRA route and then exporting it via the tread app to explore. Make sure to edit the route and then save it in tread to make the RP’s and WP’s visible in Zumo XT2 (otherwise it has just an start and end point). So, all RP and WP’s are visible in XT2. But i notice they are all displayed with the Flag symbol, instead of that only being applicable to the WP’s. Not sure if it’s only cosmetic or that the RP’s have all been converted to WP’s. Anyone else notice this? OnZumo XT1 (and older sumo’s) there was a clear distinction between RP’s and WP’s.
    TIA
    • Kenneth de Miranda Kenneth de Miranda
      TIA
      @Kenneth-de-Miranda
      The tread app make this happen, if you use the connector to export the route to your XT2 as gpx 1.1 or gpx 1.2 the points will be as planned in MRA. The viapoints are flags in the zumo
      Kenneth de Miranda 1 Reply Last reply
        @Kenneth-de-Miranda
        Kenneth de Miranda
        Kenneth de Miranda
        Kenneth de Miranda
        @Hans-van-de-Ven-MRA-Master aha, ok! Thanks! From home planning a trip this will be easy. On the road it will be a challenge. Thanks!
          @Kenneth-de-Miranda
          That's why I plan my routes at home behind the PC and transfer them via the connector. If there is something on the way, follow the detour signs.
          Kenneth de Miranda
          Kenneth de Miranda
            henry van den belt
            henry van den belt
          • Statement on map spinning
            1.8k
            Barto
            Barto
          • MRA 6.0.0 (515) Night mode
